Nisei Engineering's NEW MASTER DISTRIBUTOR!
IN STOCK FOR THE EVO 8/9
Nisei Engineering Competition FMIC / All hardware included / starting @ $695 while supplies last!
Nisei Engineering has developed and brought about revolutionary designs for the Mitsubishi Evolution 8 and 9 intercooler. Unlike other manufacturers that use existing intercoolers, Nisei Engineering pushed the limits one step further than the competition with a radical approach to intercooler design. Starting completely from scratch, combining racing technology know-how with the RR (“Race Ready”) method and built an intercooler specifically for the Evolution from the ground up.
• Core Dimensions - 25" x 12.62" x 3.7"
• Largest Exposed Surface Area - 25" x 12.62" to maximize cooling efficiency.
• Polished 3" Inlet / Outlet cast aluminum end tanks - to ensure best fitment and eliminating any chance of leakage at the welds (unlike fabricated sheet metal end tanks).
• 23 Cooling Tubes - More cooling passages than any other FMIC. Making heat transfer more effective since heat is distributed over more tubes. More cooling tubes equals, more cooling fins to transfer heat out quicker. By spreading the load over more passages allows each Cooling Tube to become more effective by operating at a lower duty cycle.
• Designed specifically for the Evo 8/9 from the "Ground Up". (Fin geometry & fin configuration)
• Tested and proven to dramatically reduce/stabilize intake temps especially with stock turbo high boost (24psi) applications : http://nisei-evo.com/forum/viewtopic.php?t=26 / http://nisei-evo.com/forum/viewtopic.php?t=25
• Stabilizing/holding inlet temperatures at approximately 10*-15*F over ambient.
• Holding pressure drops across the core below 1 psi typically between (high - low) .7 psi - . 2 psi (based on stock turbo running 23psi).
• Designed to support 800 whp. Whether your on the stock turbo or GT40R it's the only FMIC you have to buy once!
• Fitment - Retains factory crash beam. Works with stock piping or any piping kit which retrofits to stock FMIC.
• Hardware - All hoses, T-bolt clamps, ready to install.
To find out about some intercooler basics check out this tutorial :
http://www.niseiengineering.com/imag...erTutorial.swf
Nisei Engineering 6061 Aluminum Evo 8/9 Pipe kit / Model 2005 - 2006 / Available in : Nisei Red, Nisei Black, Polished / ALL HARDWARE INCLUDED / starting @ $425
• Made from 6061 Aluminum.
• CNC Mandrel Bent, to ensure accurate bend angles, highest quality & best fit.
• Direct routing design - shortest, straightest path to increase throttle response.
• Only pipe kit fully compatible with factory air box & FMIC!
• BOV - Works with factory BOV or any BOV which retrofits with stock piping.
• Aftermarket BOV flange can be added by request ( TiAl, HKS Greddy, etc. ).
• Complete kit weighs less than 4 1/2 lbs including pipes, hoses, and hardware.
• Powder Coated for flawless & durable finish.
• Kit includes : All Pipes, LICP (turbo-FMIC), UICP (FMIC-Throttle Body), T-bolt Clamps, Nutsert (Airbox), BOV extension, HOSE TECHNIQUES: Multi Ply Silicone Couplers (carry Lifetime Warranty), all hardware for immdiate installation!
• Colors available : Matte Black, Nisei Black, Nisei Red, Carbon Gray, and Polished.
• Requirements : Use of a mini battery kit or trunk relocation!
Nisei Engineering 6061 Aluminum Evo 8 Pipe kit / Model 2003 - 2004 / Available in : Nisei Red, Nisei Black, Polished & Carbon Gray / ALL HARDWARE INCLUDED / starting @ $425
Nisei Engineering 6061 Aluminum Evo 8 UIP Pipe kit / Model 2003 - 2006 / Available in : Nisei Red, Nisei Black, Polished & Carbon Gray / ALL HARDWARE INCLUDED / starting @ $299
• CNC Mandrel Bent, to ensure accurate bends angles, highest quality & best fit.
• Only pipe kit fully compatible with factory airbox & FMIC!
• Aftermarket BOV flange can be added by request (Tial, HKS, Greddy, etc.).
• Complete kit weighs less than 4 ½ lbs including pipes, hoses, and hardware.
• Kit includes: Pipes: UICP (FMIC-Throttle body), T-bolt Clamps, Nutsert (Airbox), BOV extension, HOSE TECHNIQUES: Multi Ply Silicone Couplers (carry Lifetime Warranty), all hardware for immediate installation!
Nisei Engineering Evo 8/9 6061 Aluminum LIP kit / Model 2003 - 2006 / Available in : Nisei Black, Nisei Red, Carbon Gray, Polished / ALL HARDWARE INCLUDED / starting @ $195
• Made of 6061 T6 Aluminum.
• 1 pc. Design/Mandrel bent – Allowing for smoothest flow possible.
• Mounting bracket ensures LICP to remain stable while under high boost. Keeping pipe from “popping off”.
• Hose Techniques® multi-ply (Lifetime warranty) with T-bolt clamps to ensure secure connection.
• Color available : Nisei Black,Carbon Gray, Nisei Red, Polished
• Fitment includes : Evolution 7/8/9
• Complete with all hardware
• Will work with stock FMIC. (Any FMIC that is compatible with stock plumbing)
Nisei Engineering Evo 8/9 1018 Steel LIP kit / Model 2003 - 2006 / Available in : Nisei Black / ALL HARDWARE INCLUDED / starting @ $139
Nisei Engineering Genesis Mini Battery Kit / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Nisei Black, Polished, Nisei Red / Enersys Genesis Battery, TERMINALS & ALL STAINLESS MOUNTING HARDWARE INCLUDED / starting @ $240
• Made from 6061 T6 BILLET Aluminum. Utilizing Enersys /Hawker (USA Battery Manufacturer) Genesis series battery.
• CNC Machined for the perfect fitment.
• Genesis Tray – Starts as a 1” thick billet plate, which is then CNC Machined to creating a retaining wall around the battery. Allowing the battery to sit inside the Genesis tray assembly or “pocket”, keeping battery stable. Secured Fit!
• Nisei Engineering is ONLY kit fully compatible with OEM Air Box!
• Tray also features 3 recessed locating/mounting holes to allow for trunk relocation or universal mounting applications.
• Full Kit includes : Genesis tray assembly, Enersys Genesis Battery, Brass Terminals, ALL Stainless Steel hardware! Everything needed to install into Evo 8/9 in about ½ hr.
• Colors : Nisei Black, Matte Black (Limited Production), Nisei Red, Polished, Carbon Gray.
• Compatible with : Enersys /Hawker (USA Battery Manufacturer) – Genesis 16EP, Odyssey PC680 or any battery with dimensions of – L = 7.27” x W = 3.11” x H = 6.67”.
• NOTE : Will NOT work with PC680MJ model – See Nisei Engineering Mini UBC Kit.
Nisei Engineering UBC Mini Battery Kit / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Carbon Gray, Nisei Black, Polished / Enersys Genesis BATTERY, TERMINALS & ALL MOUNTING HARDWARE INCLUDED / starting @ $200
• CNC Machined for the perfect fitment. Utilizing a Enersys /Hawker (USA Battery Manufacturer) Genesis series battery.
• UBC Tray – Starts as a 3/8” thick billet plate, which is then CNC Machined to shape. The UBC tray assembly utilizes 2 side brackets to keep the battery in locked into position.
• Tray can also be used to relocate battery to trunk.
• Full Kit includes : UBC tray assembly, Enersys Genesis Battery, Brass Terminals. Everything needed to install into Evo 8/9 in about ½ hr.
• Colors : Nisei Black, Nisei Red, Polished, Carbon Gray.
• Compatible with : Enersys /Hawker – Genesis 16EP, Odyssey PC680, and PC680MJ or any battery with dimensions of – L = 7.27” x W = 3.11” x H = 6.67”.
• NOTE : Will work with PC680MJ model.
Nisei Engineering Genesis Tray ONLY / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Nisei Red, Polished, Nisei Black / ALL MOUNTING HARDWARE INCLUDED / starting @ $160
• Compatible with : Enersys /Hawker – Genesis 16EP, Odyssey PC680 or any battery with dimensions of – L = 7.27” x W = 3.11” x H = 6.67”.
Nisei Engineering UBC Tray ONLY / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Carbon Gray, Polished, Nisei Black / ALL MOUNTING HARDWARE INCLUDED / starting @ $140
We'll keep an eye out for your emails and questions!
Thanks!
Jed
Thanks!
Jed
Absolutely correct! CNC mandrel bent. Here is how Nisei Engineering does it, check it out:
http://www.niseiengineering.com/vide...eering1018.wmv
If you have any questions, post, pm, email, we're trying to check in as much as possible!
Nisei Engineering has made the plunge! They invested BIGTIME on the Aluminum products to increased their buying power and reduced their costs!
They've assured me they will be passing the savings on to you!
I'm sure everyone who's received a quote/purchase can vouch for me!
Keep the Pm's coming and I'll knock them out ASAP!
Remember there is No Waiting on Sale Items! Everything we charge you for is IN STOCK! (unless SPECIAL ORDER ie. BOV Flange like TiAl) and will ship the same day payment is confirmed and received! (Depending of time of receipt & if daily shipment has not left already)
There is NO MAKE TO ORDER! You buy, we ship, tracking info is emailed/pm'd.
BTW, If you want to get 1018 Steel products, they've already been discontinued and what is left is IT! We'll be extending BLOW OUT prices on ALL 1018 STEEL PRODUCTS!
Let me know if you have any interest and we'll make it happen!
Jed
Jed
Ok everyone, BLACK FRIDAY IS COMING UP!!! Were going to try and put something together for everyone. If you want to contribute to being a part of the discount process you might want to check out:
Details - https://www.evolutionm.net/forums/sh...99&postcount=1
Thread - https://www.evolutionm.net/forums/sh...ighlight=nisei
If there was a time to ask for a deal or throw out some $$$ of what you want to pay this IS YOUR OPPORTUNITY! Don't say I didn't put it out there. Don't be shy, the worst thing we can tell you is no but, we're trying to work with you guys and HOOK YOU UP! So TAKE ADVANTAGE NOW!
