View Poll Results: Best Street tire - for the track?
Bridgestone RE-01R
35
17.77%
Dunlop Z1 Star Spec
78
39.59%
Yokohama Neova AD07
46
23.35%
BFGoodrich g-Force T/A KD
3.05%
Kumho Ecsta MX
4.57%
Other
23
11.68%
Voters: 197. You may not vote on this poll
Best Street Tire - 140+ Treadwear
Looking for opinions on the best street tire (140+ UG Treadwear) to use on the track. For example, in TA competitions to qualify for street class. Post up your opinion and suggested sizes. Thanks!
Keep in mind this tire would occasionally be run in wet/rainy conditions as well.
Background:
I'm looking to pick up a new set of street tires to also use on the track in street competitions and under wet/rainy conditions.
TireRack comparions:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=107
Background:
I personally LOVE the Neova's for street class. Great grip when fresh. Only downside I see is they kinda loose their luster after a few events.
I would like to add Nitto will be coming out with a GREAT street tire soon, that's what I plan to run next year if I run any events in Street class.
Edit, Id like to also add the Neova rocks in the rain:
Damn good thread. I have run the RE-01Rs in autocross here and loved them, but I haven't really run anything else to compare them too. From what I have read the Advans seem to be a little bit better.
Interested in seeing the poll results.
For combined track/street use I'll have to lean toward the Dunlop Z1's. So many people have had great luck with those on the track it's hard not to use. Only reason I recommend that over the B-Stone is your mention of track. If it was solely street I'd say the BS, but combined roles are best played by the Dunlop. Even in our wet testing the Z1 came out on top.
I have been looking into all three of these using admittedly mostly tirerack and EvoM. The Z1s seem to perform marginally better then the other two top tires (RE-01R and Neova) but cost less for a 255. I hope Im not wrong on that just throwing in my two cents. Ill be getting the Z1 SS come spring time (of course assuming there are no new players to the market)
The Dunlops seem to do a better job of not retaining heat as much as the Yoks or Bridgestones. The Bridgestones seem to lose grip fast when heat gets into them. The Yoks are the best feeling tire to drive of the three however for a track day purpose I think you will have better luck on the Dunlops. They will not fade near as bad when they get hot and they are cheaper. You also are not as concerned about precision(ie. autox) on a track day event and they will do a superb job doing what you need there. Track Days/Everyday Dunlop hands down. We ended up going to Solo Nationals with literally three sets of mounted and balanced tires. If it was a one driver car colder day...etc. I would have been on the Yoks for sure.
I have Michelin PS'2 on my car and I really like them. In the wet they have tons of grip just like in the dry. The only thing that you may not like is the softer sidewall if you plan on tracking them. For street driving they're awesome, tons of grip and a nice ride.
Treadwear: 220
Treadwear: 220
