need Evo 9 owner to test rear O2 *heater* sim patch
With a bit of help from acamus, I now understand the rear O2 heater OBD-II test algorithm enough to write a patch to simulate the rear O2 heater status so that the rear O2 sensor can be removed entirely. I need some help testing the patch though because my rear O2 sensor is still installed. I need an Evo 9 owner who has removed their rear O2 sensor, is not running the resistor mod, and has time to help me test a patch. Thanks.
MR Turco Update:
MR Turco Update:
That's actually rather clever. I like, especially if tephra was going to include it. For grins, I looked up 96940011, though, and it's a little different (although not so much that the same trick wouldn't work):
Honestly, I think it's probably just easier for folks who need this to just NOP the jsr to the test routine, and call it a day, unless tephra's going to include this as a tweakable item.
So, to summarize so far, here's a minimal addition for your XML:
96530006:
96940011:
88590015:
94170015:
Open up the ROM, navigate to the "Mods" section, change "Rear O2 Heater Patch" from "4A0B" to "0009", and you should no longer throw a rear O2 heater code. Change it back to get your CEL back.
EDIT: I originally posted a typo in the address for 96940011.
Code:
loc_2E722: ! CODE XREF: sub_2E678+A2 mov.l @(0x13C,pc), r10 ! [0002E860] = unk_FFFF8A10 mov.w @r10, r10 extu.w r10, r10 tst r8, r10 bt loc_2E732 mov.l @(0xE8,pc), r10 ! [0002E818] = sub_32780 jsr @r10 ! sub_32780 nop
96530006:
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16" />
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2e72e" type="1D" scaling="Hex16" />
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2db04" type="1D" scaling="Hex16" />
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c48e" type="1D" scaling="Hex16" />
EvoM Community Team
If you are reasonably confident in it I can unplug within the next week (man, next weekend is going to be busy with sports ! ). I'll keep an eye on the thread if no one else volunteers, but feel free to post/pm/email it to me so I can fire it up if I have a minute....
I'm still undecided about exactly how I'll implement the patch, so I need someone who doesn't mind having their rear O2 heater unplugged for a few days. It would be better to have someone who has already removed the rear O2 sensor because unplugging the O2 sensor without removing it will damage it pretty quickly.
