Boost leak test... WTF?!?
Alright... Well the story goes, a friend and I are doing boost leak tests on our cars... I have done plenty of boost leak tests, and I have now ran into an unheard of (to my knowledge) and an unsearchable occurance (who woulda thought)...
So, When doing the leak test, The boost gauge wont go past 2 psi on a 150 psi compressor... After hooking it all up, after about 3 seconds, the air being compressed leaks out of the exhaust noticeably... NOW, for the record:
1. I have never experienced this before, and ive parked my car and done boost leak tests at gas stations... i originally had the idea that since my tester was directly off of the turbo, that my wastegate was being opened from the air compressor blowing air directly and opening the wastegate and letting the air out of the exhaust...
2. Im not really trying to put both cars on jack stands and putting the car to TDC and playing with the boost leak then...
3. Ive done it on 2 Evos, one on stock cams, one with kelford 272's... i am stuck on this.. any help would be appreciated..
thanks
thanks
More likely, you've got a cylinder with partially open intake and exhaust valves.
my point is how can air get all the way down around the head/valves and then to the manifold/turbo to push the flapper open?
Yes, i will be on valves stuck open if anything as thats the only logical thing I can think of, but why would they be stuck open?
For the record I have never altered the crank position for a boost leak test, but I never thought to see if its leaking out my exhaust either. Just doesnt seek logical for me. I only really pay attention to the Intake manifold.
The volume of air that a compressor delivers will EASILY go right through the turbine housing with or without an open waste gate. It probably won't even turn the wheel. If the valves are open It'll run right through and out the exhaust.
You need to make sure all the valves are closed, then do your thing.
i wouldnt make this harder then it is.
Its a boost leak test not a compression test. if you are leaking out of the exhaust there is a valve open. I wouldnt even bother paying attention to anything past the Intake manifold with this test.
now as far as the wastegate flapper goes, i dont know how it could be, only 2 psi of air pressure is making it into the system before the leak occurs... an opened valve COULD be it, and the wastegate COULD be it... i will have to do some more trials and error when i get home.. i just dont see how both of the evos are leaking out of the exhaust...
PLEASE no more attempted flaming posts... im not new to the evo world, nor do i care to hear about how uneducated you REALLY are...
thank you to those whom had decent ideas...
