What's your Stock Turbo HP/TQ?
Starting a short little thread just to see what everyone is doing/running on their stock turbo. Throw down your mods if not in your sig and I don't care if you are running stock block, built, pump, pump+meth, E85, or race gas. Just please have a stock VIII or IX turbo and note what you are running and how you got where you are! I'll be putting in a Thread about my dyno yesterday at English Racing... If Aaron ever sends me my dyno sheet! Lets lay down some numbers!
34lbs vs. 30lbs
34lbs vs. 30lbs
Let's get started with this:
...here are the results of an AMS dyno tune for a nearly stock evo 9 (only filter and catback exhaust; stock cat, no mbc). Most predicted that a tune would pick up 20whp and that's roughly what happened - the peak numbers were +16whp and 27 lb/ft.
The best gains were around 3200rpm with increases of around 30whp and 50lb/ft.
This is an evo 9 with 10K miles; conditions 77 degree temp, 93 octane.
Here's my dyno sheet from English Racing after they tuned my EVO 8 for 93 oct
The car's going back this week for a GSC S1 cam and another dyno run
Before and after. Previously had HKS 272/272 and now running a HKS 272/280 with an upgraded FP 25psi Wastegate. As you can see the cam gave for a few extra horse top end. I gained upto 20hp from 6500k to 7800k.
34lbs vs 30lbs On the 34lbs pull, I believe that the 25psi Wastegate really helped hold mid range horsepower and torque.
Dont have my dyno sheet, but its an 06 IX, stock turbo (unported), stock exhaust mani(unported), buschur ported intake mani + tb, drop-in piston motor, cosworth m2's with gsx beehives, ets 3.5" intercooler kit, AEM Meth kit, AEM EMS, 32psi - 429awhp/480awtq
Dan
Dan
