ECU Flash on 2010 Ralliart Sportback.
Old Oct 10, 2009 | 11:59 PM
Fourdoor's Avatar
Hey guys,
I hooked up the tactrix 2.0 cable, and fired up ECU Flash and did the "Read from ECU"
After pulling the ROM from my ECU it says "Unknown ROM image" and says there are no definitions for it. I saved the ROM, but I can not look at it or manipulate it without definitions...
If I try to open the ROM in ECU Flash I get the "Use wizard to create a new definition (NOT RECOMMENDED!!! FOR DEVELOPERS ONLY)" message.
WTF do I do now?
Keith
Old Oct 11, 2009 | 02:09 AM
Evo_Jay's Avatar
Originally Posted by Fourdoor
Hey guys,
WTF do I do now?
Keith
Wait till someone makes a definition file for you ROM. or make it your self.
Its because its 2010 and they (ECUflash & ECU gurus) havent made definition files for the new ROM ids.
Old Oct 11, 2009 | 02:47 AM
tephra's Avatar
You can post up the ROM .bin/.hex file and someone can probably give you a definition for it
Old Oct 11, 2009 | 07:29 AM
Fourdoor's Avatar
Good idea! Here is the ROM... or were you talking about posting it somewhere else?
Hmmm, can't post it... invalid file type.
Keith
Old Oct 11, 2009 | 11:20 AM
JohnBradley's Avatar
Keith
Keith,
Put it in a .zip and you should be good to go
Old Oct 11, 2009 | 12:05 PM
Fourdoor's Avatar
Originally Posted by JohnBradley
Keith,
Crap! Zipped it is 340K. Size limit on zip files is 100K...
Is there anyone here I can e-mail it too for help?
Thanks,
Keith
Old Oct 11, 2009 | 12:30 PM
GST Motorsports's Avatar
Thanks,
Keith
Send me a PM
Old Oct 11, 2009 | 01:55 PM
fostytou's Avatar
EvoM Community Team
I can also host if need be.
Old Oct 12, 2009 | 03:55 PM
Have the XML 98% done. Will send over soon...
- Bryan
Old Oct 12, 2009 | 05:38 PM
Fourdoor's Avatar
- Bryan
You are the man!
Then you will just have to explain what an XML is and how to use it I am the noob of all noobs on stock ECU tuning... I am all over an AEM EMS, but this is a bit different
Keith
Old Oct 12, 2009 | 05:54 PM
SoCal Rally's Avatar
XML is a definition file used by EcuFlash, and that defines which ECU parameters are stored at which memory addresses in the ECU's flash memory.
Old Oct 12, 2009 | 06:31 PM
Evo_Jay's Avatar
In laymens terms, it makes it so you can see the tables in the ECU ROM file and values in those tables, so you can edit them using ECUflash.
Old Oct 12, 2009 | 06:43 PM
Fourdoor's Avatar
And I would copy and past this XML file into one of the folders in the ECU flash directory?
Keith
Old Oct 12, 2009 | 08:10 PM
Ok here you go.
Need somebody, hopefully tephra, to find mode23 and airflow/torque disablers but everything else is pretty much there:
base XML file:
http://norcalmotorsports.org/users/b...lliartbase.zip
Put this in:
\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
55590006 XML:
http://norcalmotorsports.org/users/b...l/55590006.zip
Put this in:
2010 Lancer ralliart Rom - 55590006
http://norcalmotorsports.org/users/b...M_55590006.zip
Old Oct 12, 2009 | 08:16 PM
tephra's Avatar
i put 55590006 mode23 into the evo x logging thread in evox section
