Autopower bar and track wheels?
Does anyone track with an autopower roll bar and transport track wheels? If so, how do you do it since the bar renders the back seat useless. Any ideas?
Great minds want to know.....
Search, someone modified their autopower so one of the bars was removable to get tires in and out.
I think this is a better option personally. > http://www.pbase.com/rsrock/trailer&page=all
I have the Autopower rollbar , and I track my car. My tire solution, was to get the same trailer as show on the website above, from Ebay for $150+shipping .
I live in Brooklyn, Ny, and so far Ive been to Mid-Ohio, Pocono, and Watkins Glen. +- 2000 miles that I put on that trailer in the past 3 months or so.
I was able to bring my tires, floor jack with stands, all the tools needed to do basic stuff.
I was able to drive 70mph, and everything was fine with the trailer .
But now Im looking to get a cheap SUV and a trailer. It so easy to damage your car, and it will suck being stuck hundreds of miles away from your house ..
I did the Harbor Freight trailer this year with the Evo trailer hitch (forget the guys name that sells it) and it was great.
At times it was a bit unnerving driving on crappy roads and watching the tralier and tires bounce around a bit thinking that the tie downs would come undone
Next year I'm going to get metal brackets welded to the trailer so I can run a rod across that can be locked down and be reasonably assured that I won't see tires bouncing down the highway.
I found no method to get tires into the car with an unmodified Autopower roll bar
oh the autopower has the flat bar across the way behind the passengers seat doesn't it. IIRC
yeah I had a custom rollbar made and I can use the backseat area if I remove the passenger seat.
but for the extra money you could go along way towards buying a trailer & hitch.
I'm the guy that modified his autopower bar. See pics and more details in the Autopower thread here:
https://www.evolutionm.net/forums/sh...7&postcount=70
I can transport 3 tires in the backseat areas - currently 255's but I believe 275's would work as well. The 4th goes in the trunk upside down and I pack stuff inside it. No trailer...
custom rollbar
Hey Riksride,
I'm the friend Letmein was referring to re: a custom rollbar and I highly recommend it. I believe it is much stronger than the autopower rollbar because it is welded in to the FRAME not bolted to the floorpan. It has significantly stiffened my car and I can fit a full set of 275/40-17 race wheels in the back seat without removing the back seats.
I paid a grand installed. If you factor in the cost of the autopower rollbar, freight and your install time, going custom was not really much more. And it also includes a clevised harness bar which I remove for daily driving. This setup has been ideal for me.
I had a mine fabbed at Farks Supercars in Bayridge Brooklyn. Alex from Dogboxracing recommend them and they will definitely work on your car with care.
Hey Riksride,
Autopower does have a bolt-on option to make a full cage - and it does already meet regs. In saying that; I'd recommend going custom any day of the week if you have the option and the $$ allows.
Well i've been putting 3 tires in all year long with the autopower roll bar. The only way i've been able to get the tires in the back seat is to remove the driver seat and then put them thru that way. Then i lift them up and rest them on the cross bar of the cage and the back seat , sorta like a tire rack. It really isn't hard to take the seat out so it's not too big of a deal. I do it mostly because i couldn't stand to drive in my race seat for more then an hour so i put the race seat in back and take out the stock seat when i get to the track.
autopower roll bar
Thanks inslowoutfast, nice custom job. The only concerns I have are losing some trunk space as was mentioned, and also it would be difficult to sell with a welded in rollbar. But it's nice to have options!
