Help: s.d. and iat calibration and set-up
Ok so im pulling my hair out with all the reading I have done. I have my car running really well with 94170015 and the s.d. patch and I have my iat temp input to the fuel temp sensor. The problem I am having is I cant find the definitive answer to a few questions.
1. My "SD MAT scaling for iat scaling" has no values in the r.h. column for the temp.
I dont know what to make of that. It also will not allow me to adjust the r.h. column to even try input values from a different s.d. rom.
2. I dont know if my ecu is reading iat. correctly. I have tried a few different ways to log iat and im confused on how I am suppose to be doing this.
I added this to my evoscan to try and log mat.
<DataListItem DataLog="Y" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="09" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-40" GaugeMax="300" ChartMin="-40" ChartMax="300" ScalingFactor="1" Notes="" />
But all it reads is like 200+ degrees. The weird thing is that if I log "air temperature" in evoscan the temps seems to be about what they should be. And if I disconnect my gm iat I get a cel and the "air temperature" goes to -88.
Any input would be great guys!
I am using these setting for the voltage for the GM IAT sensor. (Also make sure you are developer mode, it looks like you are but I would double check) Also are you using OE for the fuel temp acd?
PHP Code:
Left Side
0.1176470588235294
0.1372549019607843
0.1568627450980392
0.1764705882352941
0.196078431372549
0.2156862745098039
0.2352941176470588
0.2549019607843137
0.2745098039215687
0.2941176470588235
0.3137254901960784
0.3333333333333333
0.3529411764705883
0.3725490196078431
0.392156862745098
0.4117647058823529
0.4313725490196079
0.4509803921568628
0.4705882352941176
0.4901960784313725
0.5098039215686274
0.5294117647058824
0.5490196078431373
0.5686274509803921
0.5882352941176471
0.6078431372549019
0.6274509803921569
0.6470588235294118
0.6666666666666666
0.6862745098039216
0.7058823529411765
0.7254901960784313
0.7647058823529411
0.7843137254901961
0.803921568627451
0.8235294117647058
0.8431372549019608
0.8823529411764706
0.9019607843137255
0.9215686274509803
0.9607843137254902
0.9803921568627451
1.058823529411765
1.098039215686275
1.137254901960784
1.156862745098039
1.196078431372549
1.235294117647059
1.254901960784314
1.294117647058824
1.333333333333333
1.372549019607843
1.411764705882353
1.450980392156863
1.490196078431373
1.529411764705882
1.568627450980392
1.607843137254902
1.647058823529412
1.686274509803922
1.745098039215686
1.784313725490196
1.823529411764706
1.882352941176471
1.92156862745098
1.96078431372549
2.019607843137255
2.058823529411764
2.117647058823529
2.176470588235294
2.215686274509804
2.254901960784314
2.313725490196079
2.372549019607843
2.431372549019608
2.470588235294118
2.529411764705882
2.568627450980392
2.627450980392157
2.686274509803921
2.725490196078431
2.784313725490196
2.843137254901961
2.882352941176471
2.941176470588236
3.098039215686275
3.156862745098039
3.196078431372549
3.235294117647059
3.294117647058823
3.352941176470588
3.392156862745098
3.431372549019608
3.490196078431373
3.529411764705882
3.568627450980392
3.627450980392157
3.666666666666667
3.705882352941177
3.745098039215686
3.784313725490196
3.823529411764706
3.862745098039216
3.901960784313725
3.941176470588236
3.96078431372549
4.078431372549019
4.098039215686274
4.137254901960785
4.15686274509804
4.196078431372549
4.215686274509804
4.235294117647059
4.274509803921569
4.294117647058823
4.313725490196078
4.333333333333333
4.352941176470588
4.372549019607843
4.392156862745098
4.411764705882353
4.431372549019608
4.450980392156863
4.470588235294118
4.490196078431373
4.509803921568627
4.529411764705882
4.549019607843137
4.568627450980392
4.588235294117647
4.607843137254902
4.627450980392157
4.647058823529412
Right hand side
260.6
260.6
260.6
260.6
253.4
246.2
240.8
235.4
230
226.4
221
217.4
213.8
210.2
206.6
203
199.4
197.6
194
192.2
190.4
186.8
185
183.2
181.4
177.8
176
174.2
172.4
170.6
168.8
167
165.2
163.4
161.6
159.8
158
156.2
154.4
152.6
150.8
149
147.2
145.4
143.6
141.8
140
138.2
136.4
134.6
132.8
131
129.2
127.4
125.6
123.8
122
120.2
118.4
116.6
114.8
113
111.2
109.4
107.6
105.8
104
102.2
100.4
98.60000000000001
96.8
95
93.2
91.40000000000001
89.59999999999999
87.80000000000001
86
84.2
82.40000000000001
80.59999999999999
78.80000000000001
77
75.2
73.40000000000001
71.59999999999999
69.80000000000001
68
66.2
64.40000000000001
62.6
60.8
59
57.2
55.40000000000001
53.6
51.8
50
48.2
46.4
44.6
42.8
41
39.2
37.4
35.6
33.8
32
30.2
28.4
26.6
24.8
23
21.2
19.4
17.6
15.8
14
12.2
10.4
8.599999999999998
6.800000000000001
3.199999999999999
1.399999999999999
-0.3999999999999986
-2.200000000000003
-4
-5.800000000000004
-7.600000000000001
-9.399999999999999
-11.2
-13
-16.6
-20.2
-22
-25.6
-29.2
-34.60000000000001
-40
Im under devloper and can not edit the r.h. side for some reason. No adjustments will show up and no numbers can be put in. And yes I have the fuel temp acd set to 0E. An ideas why it wont allow the r.h. side to be edited on the iat scaling?
I just downloaded a fresh copy 9417 SD from the V7 thread and I was able to edit the values of both sides of the scalings. Are you running a pre-patched rom or one that you patched yourself?
