Akuma Motorsports Drag/show Evo8 build!
One of our customers brought us a car and gave us the green light to turn it into a monster. He wanted something fast, but at the same time cosmetically good looking. Here is what we stripped the car down to. It's leaving us this week to venture off to the body shop for a full lambo giallo orion pearl paint job, full shaved/tucked engine bay, and voltex widebody.
2003 EVO VIII BUILD
Interior
· RRM CF triple gauge pod (center console)
· Autometer triple gauge pod (A-pillar)*
· Custom black suede headliner, A, B, and C pillars, center consoles, and rear deck*
· Schroth racing harnesses, shoulder pads, and t-handle sliders*
· Bride Stradia JAPAN series seats and Lo-Max sliders/rails*
· Cusco 13-point Safety 21 roll cage with optional bars (harness, etc.) (custom color purple)*
· Beatrush bulkhead division plate
· Custom black carpeting*
· Custom CF cluster panel for digital dash
· Custom Bride fabric door panels and armrest*
· Rexpeed CF e-brake handle*
· Rexpeed CF dash cards*
· Custom CF dash cover*
· Works Bell Rapfix II quick release, flipper, and short hub*
· Ralliart titanium pedal set*
· Personal Grinta 330mm steering wheel
· Beatrush floor performance bar*
· ARC polished titanium shift knob
· Custom fabric shift boot*
Exterior
· Voltex body kit
o “Street Version” front bumper*
o Dual canards*
o Wide front fenders*
o Wide rear fenders
o Side-skirts
§ Custom passenger-side plate for side-exit ti exhaust tip*
o CF rear under-diffuser
· Seibon CF CWII-type hood
· Seibon CF rear doors*
· Craft Square mirrors
· Rexpeed CF rear window vents*
· Varis CF B-pillars*
· AMS Lexan rear windows*
· AMS CF roof*
· Do Luck CF “duckbill” trunk
· Perrin shorty antenna
· Aerocatch low-profile hood pins
· EVO VIII RS front door handles
· Custom paint job by Sano’s Customs, Dayton, NJ*
· JDM EVO VII tail-lights
· JDM EVO VIII HID head-lights
· JDM rear tow hook
· Shaved rear door handles*
· Shaved fuel door*
· Taylor external battery kill switch
· Anti-static ground strap
· Mitsubishi Galant windshield wiper nozzles
· RainX Latitude wiper blades*
Wheels/Tires/Brakes
· Volk CE28N wheels (18x10.5”, +18 offset, Diamond Black)*
· CCW Classic wheels (17x9”, Black face, Mirror polished lip)*
· Custom coated Brembo calipers (custom purple color)*
· Ferrodo DS2500 brake pads*
· Girodisc anti-noise shims*
· Girodisc lightweight, slotted/cross-drilled rotors (custom purple color hats)*
· Goodridge stainless brake lines
· Girodisc caliper dust boots and piston rings*
· Nitto NT05 tires (285/35/18)*
· Hoosier 17328 drag radials (245/45/17)*
· ARP extended wheel studs
· Fortune Auto burnt titanium lug nuts
· STM ABS removal kit
Engine:
MAP Stage 2 Short block / 2.4L
ACL Bearings
MAP 156mm Ultimate Duty Rods
ARP Main Studs w/ Align Hone
Wiseco Custom Wiseco Pistons
-10.5:1 Compression
- Using 156mm Rods +6mm longer than factory
- 87mm Bore
- Skirt Coating
ACL Race Rod Bearings
ACL Race Series Main Bearings
ACL Thrust Washers
MAP 156mm Ultimate Duty Billet Steel Connecting Rods
ARP Main Studs
Mitsubishi OEM Oil Pump and Front Case
Balance Shaft Elimination / Block Off Cap
Balance Shaft Elimination / "Stub" Shaft
Coating on rods / Oil shedding dispersant
MAP Water Pump Adapter Plate for Evo 4g64
MAP Ultimate Duty H11 Tool Steel Head Studs
Mitsubishi OEM Engine Overhaul Complete Block/Head Gasket
Fluidampr Crank Pulley
AMS Wet Sump Oil Pan
Cosworth Crankshaft Oil Scraper
AEM EVO 5-bolt Adjustable Cam Gears
Torque Solution 3-piece Mount Kit / EVO 5-Speed
Mitsubishi OEM Timing Belt Tensioner Adjuster
Mitsubishi OEM Water Pump Assembly
Mitsubishi OEM Timing Belt Idler Pulley
Mitsubishi OEM Timing Belt Tensioner Pulley
MAP Stage 5 Porting Service
Supertech +1mm Nitrided Intake Valves
Supertech +1mm Inconel Exhaust Valves
Supertech Valve Guides
GSC Beehive Valve springs/ti-retainer kit
Buschur Racing 272 camshafts
Tap/Plug EGR Port on head
Advanced Head Ceramic Coating
Drive-train
· TRE custom build 5-spd transmission
o EVO-9 first gear with TRE custom first gear modification
o EVO-8 second through fourth gears
o JDM EVO fifth gear
o HKS 4.11 final drive gear
· TRE custom 12-plate MAX LOCK rear differential
o HD side cover
o Oil sight glass
o Custom black paint
· Buschur Racing solid rear differential aluminum side supports
· AWD Motorsports 2-piece aluminum drive-shaft
· Torque Solution solid drive-shaft bushings
· Dogbox Racing transfer case
o Wave-Trac differential
o Upgraded cover and cover bolts
o Upgraded magnet
· Quartermaster 8-leg twin plate racing clutch, hydraulic TOB, and flywheel
· AMS stainless upper and lower clutch lines
Fuel System
· Aeromotive Eliminator 15 gallon fuel cell and Eliminator fuel pump with custom bracket/mounts
· Aeromotive fuel pump 30amp wiring kit
· Aeromotive fuel pump speed controller
· Fuelab 828 filter and 40 micron filter element
· Fuelab FPR and gauge
· Mocal -10 and -6 fuel line
· Russell/Earl’s hose ends and AN fittings*
· AMS high volume racing fuel rail
· Injector Dynamics 2000 injectors and PnP connectors
Suspension
· Whiteline rear sway bar and bushings
· Whiteline roll center adjust kit
· Whiteline steering precision kit
· Whiteline Bump steer kit
· Whiteline bushings (ALL others)
· AMS rear trailing arm bushings
· AFI rear lower control arms*
· AWD Motorsports-spec D2 coilovers
Engine Bay and Trunk
· Dress-Up Bolts titanium hardware
· Custom shaved engine bay*
· STM chromed coolant overflow tank
· Custom chromed P/S tank*
· ARC P/S custom polished cooler and lines
· ARC radiator cap
· Carbing front strut bar with master cylinder brace
· CBRD custom polished radiator and slim-line fan
· ETS Custom polished 4” FMIC
· ETS custom chromed I/C piping
· Tial Q 50mm BOV
· MAPerformance Rev3 intake manifold with phenolic spacer gasket
· Mil.Spec 65mm TB
· Buschur Racing custom chromed oil catch can
· Buschur Racing EGR block off plate
· Samco purple vacuum lines
· Vibrant custom chromed vacuum block
· CBRD BBK-B turbo custom chromed compressor housing and Jet Hot 2000 coated turbine housing
· Full-Race custom Jet Hot 2000 coated exhaust manifold
· MAPerformance custom Jet Hot 2000 coated O2 housing/down-pipe/wastegate dump tube
· Custom 3” stainless side-exit exhaust*
· Torque Solution motor mounts
· ARC oil cap
· Greddy 13 row oil cooler
· Buschur Racing dual stage manual boost controller
· Sparktech CDi COP sequential ignition
o Polished coil protectors
o Wrinkle black mounting plate
o Polished CDi mounting plate
· NGK BPR8ES plugs*
· OBX custom coated purple alternator pulley*
· OBX custom coated purple water pump pulley*
· Gates accessory belt for A/C removal
· A/C removed
· Dejon 4” custom chromed intake pipe
· Amsoil 4x9” intake filter
· Pro-Sport oil filter sandwich plate
· Amsoil oil filter*
· Custom mounted fuse box*
· Custom engine bay wire tucking and looming*
· Custom purple color silicone couplers*
· Breeze clamps
· Russell/Earl’s Pro-Lite hose and hose ends
· Custom purple valve cover
· STM valve cover AN fittings
· Buschur Racing cam sensor heat shield
· Gruppe-S CF hood dampers
· ARC radiator cooling plate
· Gold foil valve cover and firewall heat shielding
· AMS lightweight front cross member
· Taylor battery box and battery relocation kit
· STM black anodized radiator brackets*
Electronics/EMS
· Haltech Platinum Sport 1000 EMS
· Haltech AIT sensor
· AEM 5 bar MAP sensor
· AEM oil temperature sensor and gauge
· AEM oil pressure sensor and gauge
· Innovate LC-1 WBO2 controller and sensor
· Innovate WD-16 gauge
· Haltech IQ3 digital dash
· AEM boost sensor and gauge
· Custom audio system*
· Viper alarm system*
· Head-light and tail-light police strobes*
· 2 outlet AC/DC inverter
· Custom laptop mount and Dell laptop
· Apple iPod touch mount for G-meter
· Buschur Racing hi-lo boost switch for dual-stage manual boost controller
· Rear door pops for shaved door handles*
NOTE:
**This car will soon be running the Full-Race BW EFR 8374 T4 TS turbo kit, JMFab “Race Version” intake manifold, and CBRD custom polished half width radiator.**
Pics as it sits now:
He's in good hands! This is my personal car, so you can see why this build is by far my favorite.
More pics here:
http://forums.nasioc.com/forums/show....php?t=2076296
Dimitri@Akuma
More pics here:
Dimitri@Akuma
Yes, I know. The suby is under my personal photobucket.
I am going to upgrade the photobucket account tomorrow so we can have more bandwidth. It seems too many people looked at it at once and it got shut down, and even with deleting pics it still won't let the pics show up. I will take care of it first thing tomorrow morning.
Sorry for the delay!
Dimitri@Akuma
Dimitri@Akuma
Dimitri, just an FYI about photobucket. Their photo quality is much worse than Flickr when using them to host. I've noticed a big difference between my photos, and that is my I try to only use Flickr for my shots now.
Just wanted to give you a heads up.
Can't wait to see what this car turns into.
-Jalal
-Jalal
