Upgrading RA fuel pump
Someone correct me if I'm wrong, but pretty sure X fuel pump is same as RA pump.
If that's the case:
https://www.evolutionm.net/forums/ev...fuel-pump.html
Based off that link, you should be fine even with an X turbo swap. Probably could change the injectors though since they're PnP.
If that's the case:
I didnt know that the RA has the same as the evo X. I have a turboback exhaust, evo x fmic, UR IC piping and UR intake. Im getting a custom tune and that should do it for engine mods for a while. If the stock fuel pump can handle that without going 100% ill be happy
if those are your mods dont worry about injectors or pump for now you wont be at 100% on either. HOWEVER........change out that POS stock fuel relay and zip tie/safety wire your fuel pressure regulator hose or you will end up like me!
what would be even better is an in-tank anti-surge set up. on long left handers with semis (and under half to a quarter of a tank) often get fuel surge issues...
