My Evo work-in-progress pics
Old Jun 8, 2004 | 02:07 PM
Ludikraut's Avatar
Smile My Evo work-in-progress pics
White 2003 Evo:
AMS Turbo kit with BB 50 trim turbo (PTE Housing)
AMS VSR intake manifold with Works 65mm throttle body
AMS Ported Head with Supertech valvetrain
Ross Pistons (8.5:1)
Crower Rods
780cc injectors
HKS 280 cams timed at +2/0
Vishnu adj. cam gears with clear camgear cover
Ludikraut custom exhaust piping (made by AMS)
AMS resonated test pipe
AMS downpipe
AMS IC and AMS IC piping (upper and lower)
saikou Michi Dual Catch Can
Ludikraut custom intake (made by AMS)
TIAL BOV
Exedy Twin Metallic (HD) clutch
Innovate LC-1 with XD-1 or Innovate LM-1 wideband
Innovate LMA-3
Summit Racing battery trunk relocation kit
Cusco V-brace, trunk bar
Custom brake ducts and brake air guides
AMS Front Splitter
Customized Vishnu rear diffuser
Rotorpro rotors, Hawk HPS or HP+ pads with Girodisc Ti pad spacers
Rolling on 18x9 TDR Pro Race 1.2 with Good Year Eagle F1 GS-D3 265/35 tires on the street, and stock Enkeis at the track.
Omori gauges mounted in Gruppe-S gauge panel (replaces the radio/A-C panel)
Alpine head unit, Infinity speakers
Odds and ends: ’05 cupholder added, 2.0t badge (from Saab), battery cutoff switch, Vibrant CF shifter knob, sound deadening provided by .... UPS moving blanket in trunk!
Tuned by: AMS Crew (Martin & Chris) and myself
All this results in:
Peak power is ~421whp at 7200 RPM (93 Octane, 22psi), fuel cut at 9000 RPM
Spoolup is at ~3200 RPM in lower gears, ~3000 RPM in higher gears (e.g. 4th/5th)
Full spool is at ~3700 RPM in lower gears
Engine VE > 100% between 4000 – 7250 rpm
Engine management is currently via AEM EMS, logging via AEM and Logworks
l8r)
Attached Thumbnails My Evo work-in-progress pics-radio-panel-razo_shifter01b.jpg
Last edited by Ludikraut; Jun 6, 2008 at 08:16 AM. Reason: Edit to make this my current state-of-mod list
Old Jun 8, 2004 | 02:13 PM
Ludikraut's Avatar
Arrow Install pics...
Ok, here's the front speaker installation...
Attached Thumbnails My Evo work-in-progress pics-evo_passenger_door_speaker_install_in_progress_sm.jpg   My Evo work-in-progress pics-evo_passenger_door_speaker_install_done_sm.jpg   My Evo work-in-progress pics-evo_driver_door_speaker_install_done_sm.jpg
Old Jun 8, 2004 | 02:14 PM
Ludikraut's Avatar
Talking Last for now...
...and here's a couple more finished install pix...
Attached Thumbnails My Evo work-in-progress pics-radio-panel_install_done03b.jpg   My Evo work-in-progress pics-radio-panel-razo_shifter02b.jpg
Old Jun 8, 2004 | 02:23 PM
rentaslut's Avatar
K where did you get the "Craig Hardy's dash panel" ????
how much $$$??? PM me!
Old Jun 8, 2004 | 02:30 PM
Ludikraut's Avatar
You can get it from Gruppe-S for ~$160 (www.gruppe-s.com). I was part of the fourth group buy ... there's a whole thread dedicated to it: https://www.evolutionm.net/forums/sh...ad.php?t=74699
Old Jun 8, 2004 | 02:55 PM
Gruppe-S's Avatar
Glad you like the gauge panel! Everything is looking good bro! keep up the good works!! Can't wait to see the final touch of your EVO!
Old Jun 8, 2004 | 06:21 PM
justchil's Avatar
Just a couple ?'s
How good is the stock wiring to the door speakers?
How much of a pain are the door panels to get off/on?
Did you leave the pillar speakers hooked up?
Nice setup tho I had those same speakers & alpine amp in my celica
Old Jun 8, 2004 | 08:09 PM
db8 na's Avatar
lookin good!
Old Jun 8, 2004 | 08:24 PM
Ludikraut's Avatar
Post ...answers
Originally Posted by justchil
Just a couple ?'s
IMHO the stock wiring to the door speakers sucks a$$, the reasons being:
- does not use a crossover for the front component speakers
- front speaker wiring is simply split into two as part of a PITA harness that's located near the wheel wells in the passenger compartment (one on each side)
I chose to route new wiring completely ... if you look closely at the door pics, you'll see where the new speaker wire (wrapped in white electrical tape) goes from the door to the passenger compartment. Also because the Infinity's use a crossover, I chose to mount the Infinity tweeter on the door instead of trying to use the stock location.
Not bad at all. I did get a copy of the service manual ($cheap$ off eBay), which showed me where all of the mounting points were at. As long as you use something flat and wide (read: not a screwdriver, rather something kinda like a bottle opener), the panel comes off without too much of a problem. It re-assembled fairly well also, meaning that I didn't pick up any additional rattles
Nope, they are still connected to the stock wiring, but since I bypassed the front speaker wiring altogether, they are off. For the rear speakers I did use the stock wiring, I even bastardized the stock speakers and connected the Infinitys using the stock speaker harness.
All-in-all it sounds 1000% better than stock ... also got an Infinity Basslink sub waiting to be hooked up, but I'm going to wait until I relocate my battery to the trunk b4 I hook it up.
l8r)
Old Jun 9, 2004 | 01:54 PM
jong's Avatar
Hey looks good. I was hoping you could tell me how you like your razo shift knob? I need a new shift knob, but I haven't been able to find one that really caught my eye. That one I've seen on lancershop, but I can't decide if I like it or not. Maybe some more pics and/or your personal experiences with it? Thanks!
Lol scratch that- just found another thread where you talk about it and share another view. I think I like it, but I'm not too sure about the shape.
Old Jun 10, 2004 | 03:40 AM
Evo8DownUnder's Avatar
Like the stereo relocation, but would REALLY like to re-locate the HVAC down there instead, to free up room for a double DIN stereo up the top
Anyone know if ANY manufacturor makes a HVAC relocation kit to accomplish the above.
Old Jun 10, 2004 | 05:39 AM
SuperHatch's Avatar
I've mentioned it in another thread, and I'll mention it again.... I do not know if this works, but it's what I may try someday. The 3G Eclipse HVAC controls are layed out in the same manner as our factory controls, but they are in a DIN sized panel under the radio in the Eclipse. This HVAC control panel looks identical to the HVAC panel that is used in the UK EVOs that have the HVAC controls in the radio relocation pocket. I think this panel can be made to work with our car, if not a direct hookup it can probably be bastardized to work.
- Steve
Old Jun 13, 2004 | 03:14 PM
outsider's Avatar
looks good - what color are the DEFI gauges at night btw?
Old Jun 13, 2004 | 09:17 PM
Ludikraut's Avatar
DEFI?? Dunno ... I got Omori gauges, which are fully color adjustable. Pictures coming shortly.
Old Jun 14, 2004 | 08:37 AM
speedomodel's Avatar
I've wondered the same thing. Our controls use a low-tech wire linkage and I believe the UK HVAC controls are all electronic. If so, I don't think it would be an easy conversion.
