2009+ Ralliart Evoscan addresses / info
This will evolve into a central thread where people can find correct Evoscan address's to properly log their 2009+ Ralliarts.
First, check this first post for your ROM ID and check for the *known working* address's for your ROM ID / Model Year and Market.
If what you are seeking is not listed then:
Second, post what ROM ID / Model Year and Market you have and then what you are trying to log and with what current address.
Example:
ID 55590342
2010
USDM
Looking for:
Manifold Air Temp
Currently logging request address: 23808632
Does not log correctly
ID 55590007
2010
USDM
Currently logging correctly:
RPM
Load
TimingAdv
Barometer
PSI
Knock Sum
Accel Pedal Position
TPS
Active WGDC
IPW
IDC
Corrected Timing Advance
Manifold Air Temp
Coolant Temp
Intake Air Temp
Speed
STFT
LTFT idle
LTFT Cruise
LTFT In Use
Boost Error (for psi-target, needs rom mods)
Front Oxygen Sensor
Rear 02
Knock Voltage
Battery Level
Injector Latency
InVVT (target)
ExVVT (target)
InVVT (actual)
ExVVT (actual
MAF Volts
MAF Airflow
Altmap Status (for Tephra map switching, needs rom mods)
SST Transmission Temp
External Wideband A/F Ratio
XML:
ID 53600010
2009
USDM
RPM
Load
TimingAdv
PSI
Knock Sum
TPS
Active WGDC
IPW
Coolant Temp
Intake Air Temp
Speed
MAF Volts
XML
Example:
ID 55590342
2010
USDM
Looking for:
Manifold Air Temp
ID 55590007
2010
USDM
RPM
Load
TimingAdv
Barometer
PSI
Knock Sum
TPS
Active WGDC
IPW
IDC
Manifold Air Temp
Coolant Temp
Intake Air Temp
Speed
STFT
LTFT idle
LTFT Cruise
LTFT In Use
Front Oxygen Sensor
Rear 02
Knock Voltage
Battery Level
Injector Latency
InVVT (target)
ExVVT (target)
InVVT (actual)
ExVVT (actual
MAF Volts
MAF Airflow
XML:
Code:
<DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="2380875c" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor=".1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="23808784" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A1F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AA4D" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="PSIG" LogReference="PSIG" RequestID="2380872E" Eval="(x/4*0.1953125)-[Baro]" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A63" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Air/Fuel Ratio (Map)" LogReference="AFRMAP" RequestID="2380890d" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="238095FD" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="2380870D" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808b6d" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AA88" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="IDC" LogReference="IDC" RequestID="23808763" Eval="[IPW]*31.25*x/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Corrected Timing Advance" LogReference="Corr_TimingAdv" RequestID="238089ff" Eval="x-20" Unit="degrees" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="23808672" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808653" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380866D" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="238087FF" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088b0" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088C1" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="WGDC Correction MUT" LogReference="WGDCCorr" RequestID="23808783" Eval="0.5*x-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Boost Error" LogReference="BoostError" RequestID="238085A2" Eval="(x-128)*0.19347/4" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-6.1" GaugeMax="6.1" ChartMin="-6.1" ChartMax="6.1" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="2380867d" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="23808681" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Knock Voltage" LogReference="KnockVolt" RequestID="2380872b" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="23808703" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Injector Latency" LogReference="InjectorLatency" RequestID="23808945" Eval="x" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809526" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809532" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380955e" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="2380956A" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808F78" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="MAF Airflow" LogReference="MAFgs" RequestID="238087f8" Eval="x*0.02" Unit="gs" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="Altmap Status" LogReference="Altmap Status" RequestID="23805000" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="SST Transmission Temp" LogReference="SST_TM_Temp" RequestID="CAN28-0" Eval="x-50" Unit="Deg F" MetricEval="x-50" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
ID 53600010
2009
USDM
RPM
Load
TimingAdv
PSI
Knock Sum
TPS
Active WGDC
IPW
Coolant Temp
Intake Air Temp
Speed
MAF Volts
XML
Code:
<DataListItem DataLog="Y" Color="" Display="Throttle Posn" LogReference="TPS" RequestID="23808701" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="2380874E" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Load (Fuel)" LogReference="LoadFuel" RequestID="23808776" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="340" ChartMin="0" ChartMax="340" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A0F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="50" ChartMin="-15" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A53" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="PSIG" LogReference="PSIG" RequestID="23808722" Eval="(x/4*0.19347)-14.5" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Intake Air Temp" LogReference="IATS" RequestID="23808659" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Coolant Temp" LogReference="CTS" RequestID="23808647" Eval="1.8*x-40" Unit="def F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Speed" LogReference="Speed" RequestID="238087EF" Eval="1.26*x" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808F58" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Battery" LogReference="Battery" RequestID="238086F7" Eval="x*18.75/255" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Priority="1" Visible="False" />
I'm going to need some help from you guys for 2009 as I don't have a 2009 I can log whenever I want and I can't remember what works correctly and what doesn't
- Bryan
- Bryan
Awesome, Thanks again Bryan!
Nub ? though. My stock internal id was 53600010 and after I flashed to the GST V2 basemap it was changed to 53600009. Does this matter now for logging purposes, since every rom id has its own address for data?
ID 53600010
2009
USDM
Currently logging request address: 23808659, eval - 1.8*x-40
May not be wrong but this is what I have been logging for IAT and I was seeing 188F. I will be more help on this once I have the stock air box out.
Manifold Air Temp
Currently logging request address: 23808661, eval - 1.8*x-40
With ambient air temp at 66F, MAT was 75F @ cruise/normal driving. Seems correct.
Knock Sum
Currently logging request address: 23808A53, eval x
2 Byte RPM
Currently logging request address: 23808743, eval 3.90625*x
correct
2009
USDM
Manifold Air Temp
Knock Sum
2 Byte RPM
correct
So i did a little logging on the way to work today. Traffic was bad so it was really fairly useless. But I'll report what does not seem to be right. I am logging using the default address in evoscan 2.7 for USA RA EVO X. I had done a bunch of searching and had most of this stuff working correctly, but had some laptop issues and lost the addresses
53600010
ExVVT 23809462
Seems to be InVVT as it follows my intake map almost exactly. Not sure if this is target or actual.
InVVT 23809444
Return -63 constantly
IPW 2380A94C
Returns 0 constantly
IDC 2380874E
Returns 0 constantly (IPW is not working)
IAT 23808659
146 to 167 degree. Seems strange
LTFT cruise 2380457D
Returns -21 constantly
Ill post more stuff when I get a chance.
53600010
ExVVT 23809462
InVVT 23809444
IPW 2380A94C
IDC 2380874E
IAT 23808659
55590006 2010 Ralliart
Trans temp isn't reading correctly in F anyway. What EVAL should be used in there for correct temps in F? Currently it has X-50 in there.
I put 1.8*x-40 in there for Fahrenheit reading. Just making sure this is correct.
I have been logging this address for IAT and I can defiantly confirm that this is wrong. How do we figure what is right? MUT Tables? So then this would be the xml code to access the MUT tables?
<table name="MUT Table" address="???"> (not sure of the address)
<table name="X"/>
<table name="Y"/>
Piper, it seems that you may have a lot of knowledge regarding this topic. I am just starting to learn this so if at all possible any of your help would be completely appreciated.
<table name="X"/>
<table name="Y"/>
