Boost control?
Originally Posted by Fourdoor
I use the AEM for my boost control with the GM boost solenoid. In my opinion it has the best "raw" boost control out there, but the feedback system sucks really bad. Get the base tune for the boost control correct and you can run with the feedback turned off.
Keith
Keith
Robert
The feedback features that are available with boosting thru the AEM are RPM based boost or vehicle speed based boost. These are the most common used. You can ramp up/down boost based on a rpm level or vehicle speed. The AEM also has a high low switch for boost like on most EBC's and some MBC's. With these features you could use the boost control as an additional traction control devise along with the traction control features already built into the AEM software. Apexi's/Greddy's solenoid can also be used, and with the proper fittings and equipment you could have all your vacuum line be stainless steel with threaded fittings so you don't have to worry about a leak or a vaccum line blowing off.
Also, the 1.11 version of the software has a built in boost cut feature if a vacuum line were to blow off and no longer had control of the wastegate. There have been many discussions on the AEM forum on how to route the vaccum lines on the GM solenoid in case such a failure would occur and default the boost to wastegate pressure, but I have never found an answer thus the added boost cut feature in the new software revision cancels the need for that feature. Most people just added tons of fuel and retarded timing above the the highest load cells in there fuel and ignition maps.
I agree with Keith.
If you setup the EMS with Speed dependent control, it is simple and works very well.
The feedback works very very well also if setup correctly. You have to ensure that your target boost comp table is setup correctly and there is a certain way of doing this. Involves drawing a line from the lowest boost setting teh wg allows to your target boost.
Once that's setup correctly, you can then massage the boost error duty table to ensure the control isn't too abrupt, basically on a stock turbo evo you want cut the percentage value down low for small overshoot and ramp it up later.
Remember there are 2 methods of boost control, I don't use the integral method.
All said and done, you cannot get better results with the manual controller.
Sean
Sean
Originally Posted by Sean I
I agree with Keith.
Sean
Sean
Later,
Keith
I tried to get one at the gm dealership (boost solenoid) and he thought i was crazy. Told him it wasn't going on a gm car and he was like i need the vin # perferrably to look up the part. Was a total pain in the ***. He said either way they would have to order it....i was totally being kool with the guy, but i couldn't get it ordered.
So, does anyone know of a vin i could use to order this thing lol...or a gm part #? seems crazy i know! Thanks, Wayne
Listen
Go to www.aempower.com
Search the forums under sensors. You will see a part # for the GM solenoid, you can also use one that perrin has available.
Hope this helps, and saves you some effort in getting what you need.
Sean
Sean
Thanx--after some searching there i found the b/c sol. and the pigtail part #'s. called up the dealership and will have them for me on Mon. I am on my way lol. I am picking up the aem ems tom. Have to install my w/r turbo and meth kit this weekend. going to be busy!
FS[Northeast]: AMS Electronic Boost Controller
EvoooB
Feb 27, 2017 05:59 PM
WTB[SouthEast]: Need OEM boost controller pigtail harness
Igaly1021
Jun 21, 2016 03:59 AM
sleeperevo8
Dec 21, 2005 12:25 AM
