AEM EMS Get tuning help for your AEM EMS system.
Speed density vs MAP?
Old Jun 6, 2005, 06:47 PM
Kwman's Avatar
Question Speed density vs MAP?
Could someone please help me by listing a compare/contrast of Speed density Vs MAP. Pros/cons, anything to help me better understand the two and their differences. At this point the vagueness of my knowledge is limited only to the difference in terms. Thanks guys!.
Old Jun 7, 2005, 06:10 AM
Kwman's Avatar
First person gets a hug.
Old Jun 7, 2005, 06:16 AM
electricevo's Avatar
The only things i gather from the two are the following:
Open element air intakes and VTA blowoff valves can be used without the computer misreading the airflow. But, i heard that speed density is harder to tune accurately....Maybe someone could chime in and explain why...
I hope that helps a little, maybe you could pm gurujack, he knows a lot of stuff about this topic.
Old Jun 7, 2005, 06:31 AM
Kwman's Avatar
GuruJack eh? Will do. Thanks for the help, and yeah i know yo can use speed density to work with open element intakes and VTA BOVs but i just wanted to know the differences between that and the MAP, which is more accurate or tunable or which is ideal for what situation and such. Thanks tho i'll pm him now.
*hug*
Old Jun 7, 2005, 07:30 AM
kcevo's Avatar
Might want to change the title to Speed density vs. MAF to get more responses, as MAP and speed density are the same.
Old Jun 7, 2005, 07:35 AM
Kwman's Avatar
^Lol, this might sound crazy but thats all i needed to know! wow...im gonna go cry. Thanks for the help man thats what i was wondering.
Old Jul 20, 2005, 02:31 AM
joeracer321's Avatar
I would say that if the car will be used as a daily driver, you should stick with the MAF, but if it will see a lot of track time, go with the MAP set up. The MAP will offer less restrictions, where the MAF will give you a little better drivability.
Old Jul 20, 2005, 08:51 AM
racegate's Avatar
Thats not true. Both setup properly, offer the same drivability. Once again, its only as good as the person setting it up and tuning it.
Old Jul 20, 2005, 12:18 PM
PPI
PPI's Avatar
/\ good point on the tuner. many cars have gone well into the elevens on piggypagcks. It really depends on the knowledge of the tuner of that particular system you are using
Old Jul 20, 2005, 02:24 PM
rlazer5000's Avatar
This is a little off topic, but how the hell do you guys pass emissions with a stand-alone EMS?
Old Jul 21, 2005, 08:02 PM
mooreboost's Avatar
You can start by moving to a state that doesn't have emissions.
Old Jul 21, 2005, 10:35 PM
rlazer5000's Avatar
^^ LOL, I am actually. Does Michigan have emissions testing at all?
Old Jul 22, 2005, 12:43 AM
SeanJhn9's Avatar
the way i'm doing it is by registering my car in a county that doesnt have to have emissions, but i'm in idaho
Old Jul 27, 2005, 01:57 PM
theace's Avatar
to the hell with emissions
Old Jul 30, 2005, 12:44 PM
ninjadoc's Avatar
Depends on how they test emissions. If they just do a sniff test...lean it out. If they hook up to the OBD2 connector...switch back to MAF for emission testing, then go home and switch back. A pain but that's what I'm gonna do if my car is ever finished!
Quick Reply: Speed density vs MAP?
