aem ems 2 step lunch help
go into setup and click rev limiters. you will see main and 2 step. put you ign and fuel cut at what you want to launch at. for example 5500 for ignition and 5600 fuel cut. then play with the 2 step retard rev, put it anywhere from 5k-5400rpm. I had mine set at 500rpm's before my ignition cut and it would build 16psi in a second, but it was very loud. it's not a good idea to sit on it too long also. also set the 2 step input to "switch is always on" and set what vehicle speed you want the 2 step to turn off. mine is set up at 5mph. but if you set the vehicle speed up right you can dial in your launch and reduce wheel spin. hope this helps.
Jsiebert
Apr 6, 2016 02:16 PM
