hks dli / AEM ems
hks dli / AEM ems
I have the HKS dli on the way. Yippee!!
Anyway... I have had mixed advise on install. I have been told to just plug and play with no adjustments, but with this being done the results end up with fried coil packs. I was advised to go into the set up for AEM and adjust the coil dwell for cdi.
Can i just plug and play or is there a need to tune? Anyone that has already trouble shooted this with an intelligent answer would be greatly appreciated. Thanks again!
lance
lance
me too. 6+ months without even a hiccup. It's an idiot-proof install, just make sure you grab a good ground. I'll post a pic of how I mounted mine in a bit. I think it makes for a cleaner look than I have seen on some other cars.
Excellent pics. Thanks for all the input guys. I am going to go with plug and play and no adjustments.
I am only running stock turbo right now with about 22-23 lbs of boost.....so I guess my other question might be for advice on plugs and gap with this system. I am currently running the NGK/BPR7ES STOCK #2023 from NAPA and changing every oil change or every other gapped at 28.
Thanks again!
Thanks again!
