Need some help with A/C fan always running...
When i turn my key on before i start the car, the AC fan solenoid clicks and the AC fan stays on all the time. Can someone help me out with this???? Thanks Ray
Hey man some of the PW Output tables that control the fan speed depending upon coolant tempature were set backwards in the AEM Base cal files but not all. You also might just check the fan speed on and off params in the output listing.
Anytime I try to run 1.19, with a very cold start my stat sync turns on and off rapidly until tthe car warms up completely so I quit running it being afraid of what else I would find later on. I posted the question on AEMPower but no answer. Hopefully you don't encounter this either.
i had mine with the same problem, when you put your key in the ignition and putting it on without starting, the 2 fans immediately starts running. what would be the problem?
is it the fan control near the radiator or the fan control switch on the switch box?
please help!!!
please help!!!
Spythere
Jul 5, 2016 03:09 AM
bubbleboy1972
Lancer Troubleshooting
Apr 22, 2011 12:41 PM
