serial port card for laptop
Ive got a brand new dell laptop. Which serial port card do I need to run the aem ems off my computer. and will I need any differnt connectors serial cable to the serial cable on the aem?
thanks its been a long time coming finally everything is coming back together all I have to do is wire in some gauges and fire her up. It takes time when your doing it in your own garage. If you can use a serial to usb adapter how comes its not working for me.
You could also get a wireless serial device server so that you don't have to deal with hooking up a cable anymore....
http://www.digi.com/products/serials...rvertswmei.jsp
USB adapters are famous for causing problems with the AEM. It will work, I use one. But over time it will corrupt the cal and cause weird problems. If I'm doing a lot of street tuning I'll have to reload the cal file to the ECU every couple weeks to clear out all the bugs. I bought a serial card to try to get around this BS, but I haven't been able to get it to work in the whole 5 minutes I've spent on it so far...
I wonder how common is this problem????
