AEMlog scaling
AEMlog scaling
Hi
I am trying to find out how I can have the changes I make to scaling be stored.
I open up one log and chang the scaling for map#load from max = -0.18(something) to 27, and I have to do this everytime I open up a log.
Is this something I can adjust in either AEMpro or AEMlog ?
regards
Gudmundur
regards
Gudmundur
get your scalings & colors set to your liking within aemlog.
go to templates/save = "just create a name of some sort". i also go the the disc icon & press that too!
then go to templates/config/on the top right you will see a browse button, press that & look for the file you jsut created, it maybe within templates of the log, but just search for it & hit ok
reopen templates/config/goto the bottom & click the active box & then hit browse & find your file again. this applies your template everytime you open aem log.
i have several templates for internal logging, logging onto the pc & idle settings
it is easier to view 3 rows of data vs. all the data within 1 window. i also like the dta with a black background to. that is all configuarable. enjoy
Hi and thanks for some good information
I have been using templates.
But my scalings do not seem to be saved within my templates for some reason.
What I do is I go to Graph/Setup/Edit and I change one of the max parameters and then close that window and the graph that I currently have active is changed immediately.
Then I save the template, close the log file without saving and open it again and the max setting I just changed and thought I had saved to the template is still in default value.
r
r
r
r
i right click the displayed data variable/parameter on the right, change the scalings there, then do both save routine's as mentioned.
