AEM EMS Get tuning help for your AEM EMS system.
just installed aem and the car wont start
Old Jul 1, 2011, 07:14 PM
Aby@MIL.SPEC's Avatar
Aem map sensor to oem evo
PIN# OEM COLOR WIRE AEM COLOR WIRE DESC
91 black black ground
81 grey red 5v
73 yellow green signal
the wiring is correct as i have just got done doing it on another evo last week.
MAP sensor:
-- red from AEM sensor goes to grey from MDP sensor on top of manifold = 12v power
-- black from AEM sensor goes to black from MDP sensor = ground
-- white or green from AEM sensor (they now have a white wire but the instructions mention green) goes to yellow from the MDP sensor = signal
AIT sensor:
-- black wire from the maf plug and the red/blue wire from the maf plug are for the ait sensor. polarity does not matter, but if you have a white wire for the pigtail that is power and black is ground. You would hook black from the pigtail to the black wire from the maf sensor and the white wire from the pigtail will go to the red/blue wire from the maf sensor
Boost solenoid:
-- red/yellow wire is the 12v switched ignition power and the light green wire is the switched ground wire. Wire the positive side of the solenoid to the red/yellow wire and the ground side to the light green wire.
there is also a fuel gauge wire that i need to locate. if you dont disconnect 1, i forget which, your fuel gauge will read empty with ~2 gallons in the car.
Old Jul 5, 2011, 08:02 PM
n2oiroc's Avatar
81 grey red 5v
MAP sensor:
AIT sensor:
Boost solenoid:
i got the 5 bar and ait setup and the car is already running 10x better except for a hunting idle after 30 seconds or so when i think the o2 feedback kicks in. i cut the wideband controller wires to snake them thru the stock o2 sensor grommet but lost the sensor end some how so im running without an o2 sensor so im sure thats the problem. i have the connector end coming from aem 3 day so i get it for this weekend. i also scrapped the stock bcs and put a hallman in, i dont care for ecu controlled boost.
thanks for the help!
Old Jul 5, 2011, 11:38 PM
^ the oem bcs is ok, as long as you have a jet in-line.... i actually went from oem bcs to hallman, back to the bcs.
honestly, any mbc is set-n-go, so it is easier....but if you want more, you can get it with the oem bcs.
Old Jul 6, 2011, 08:20 AM
n2oiroc's Avatar
on my last car i got tired of fighting to get fast spool without spiking while not overboosting to heck on cold mornings. i would have it dialed in perfect during the day and in the morning the temp would drop 35* and i would be 4lbs over. with the hallman i just give it 1/2 turn and im good. its just less hassle for me. plus with an ewg it doesnt sound like a machine gun.
Old Jul 6, 2011, 08:35 AM
toyota4me2's Avatar
Not to hijack but could i get a comparison stock map cal file maybe from someone, I started out with my aem and trying when I have time to mess with it, Finally have idle and low load running but not full boost , Been reading alot and set alot of things with very useful tech on here thanks
Old Jul 6, 2011, 10:28 AM
n2oiroc's Avatar
what we really need is a aem faq thread pinned to the top with base maps and how to's. im trying to setup a boost cut and cant find it in the menu's!
Old Jul 6, 2011, 11:10 AM
its in several locations:
1. boost control "T"
2. set-up / rev limiters "T"
Old Jul 6, 2011, 01:47 PM
n2oiroc's Avatar
this it? holy hell is that set high!
"fuel cut load" [514.98 kpa]
Old Jul 6, 2011, 06:31 PM
browningderek's Avatar
^^ Yes thats it. When you use the map sensor wizard to set up your 5 bar the boost cut defaults to sensors max pressure. Its up to you to set it where it needs to be. If you want to read it in psi go to configure/units. scroll to " load units" and select "psig". Click apply and ok.
Old Jul 6, 2011, 08:34 PM
n2oiroc's Avatar
great, thanks! i just need more time to get familiar with it. i had a hydra ems on my sti and that was no problem after i got familiar with it and aem is supposed to be a lot more user friendly.
Old Jul 8, 2011, 02:54 PM
n2oiroc's Avatar
installed the uego, but its reading super rich. for some reason the #1 o2 cal table on the base map maxes out at about 8 afr and 4.99 volts. switching sensor type doesnt change it. i cant change it to get it up to 18 afr. ideas?
edit: nevermind, afr units werent set to gasoline! im thinking my serial to usb adapter isnt working right, i keep losing connection and its corrupting files.
Old Jul 14, 2011, 10:37 AM
n2oiroc's Avatar
switched to the io gear usb to serial adapter that everyone says works, but im still having problems. the wideband readings are all over the place. any ideas? here is a vid. notice the comm errors.
edit: i watched the voltage going into the ecu from the wideband controller and its goofy there, reading 3 volts with the engine off. so im thinking something is funky with the sensor. i checked all the wiring and its solid. the uegu controller isnt showing any faults.
http://www.youtube.com/watch?v=1FAt_tCIWSc
Old Jul 14, 2011, 02:18 PM
TheBoz's Avatar
What pin did you hook up your wide band to. It looks like something is wrong, or a bad ground somehwere.
Old Jul 14, 2011, 03:29 PM
n2oiroc's Avatar
white wire to pin 76 and brown to 92 as shown here and they are soldered in. http://www.aemelectronics.com/Images...%2030-2310.pdf
ground is to the steering column support and has good continuity to the chassis, power is a fuse tap to an open fuse under the dash. with the car running its at .5 volts until i tap the gas then it drops signal. with the uego out of the exhaust and the engine off its reading 4.8V.
the controller is all green and shows no faults. i guess ill get a long test lead and ground it directly to the battery and move the power supply. im out of ideas after that.
Old Jul 14, 2011, 05:27 PM
TheBoz's Avatar
When you log your AFR's whare are you seeing.
ALso make sure to sync you WB.
http://www.youtube.com/user/AEMEMSTe.../0/RSLA97NkuCU
if when you tap your gas the WB pegs out to full lean that is a tip in issue.
Quick Reply: just installed aem and the car wont start
