AEM EMS Get tuning help for your AEM EMS system.
just installed aem and the car wont start
Old Jun 20, 2011, 01:24 PM
n2oiroc's Avatar
bone stock 03 gsr, put a used 1313 in. loaded the correct maf cal, set the tps and went thru all the stuff in the instructions. car cranked and fired a couple times but not enough to actually run. i noticed the coolant temp was way off so i checked all the sensors in the cal and made sure they were correct. the coolant temp is now reading correct, but it wont fire at all, just cranks. i dont have the uego, just the stock o2 sensors, but i dont see how that would keep it from starting. ideas?
Old Jun 20, 2011, 02:19 PM
TheBoz's Avatar
Did you set your base ignition timing? After that you might need to add more fuel to the map to get it to stay running.
Old Jun 20, 2011, 02:39 PM
n2oiroc's Avatar
i did not, ill hook it back up and try again.
i tried but cant set the timing until the engine is running.
Old Jun 20, 2011, 03:43 PM
n2oiroc's Avatar
ok, got it running. besides a blown fuse the base map is absolute garbage. not nearly enough fuel to run the engine. i had to bump up the idle portions of the base fuel map a lot.
Old Jun 20, 2011, 03:49 PM
project_skyline's Avatar
Stock AEM cal won't do much for you. Pretty much gotta map the whole thing.
Old Jun 20, 2011, 04:15 PM
n2oiroc's Avatar
yeah, i dont know why they even bother. when i had my sti i put a hydra on it and the base map ran better than my fully tuned stock ecu map with a 35r and big injectors!
Old Jun 20, 2011, 09:14 PM
TheBoz's Avatar
glad to hear you got it running. If you need any help with tuning feel free to ask. There are also a lot of people on here that are willing to help out.
Old Jun 20, 2011, 09:30 PM
rodent's Avatar
I can send you my AEM v1 map if you need it for reference.
Old Jun 21, 2011, 07:42 AM
n2oiroc's Avatar
stock injectors, maf and everything?
Old Jun 21, 2011, 07:46 AM
n2oiroc's Avatar
i appreciate it! its my first time with an aem, but i got pretty familiar with my hydra on my sti and this isnt too different. im sure ill need some tips here and there. today im going to put the wideband in so im not flying blind. for now im getting it dialed in on the stock motor so when i drop my built 2.2L in i can dial it in for break in.
Old Jun 21, 2011, 07:59 AM
TheBoz's Avatar
Also I would get on the AEM forums, and do some reading there. Be sure to read the Cold Start and Idle thread on here.
Get that ***** switched to Boost Comp.
Old Jun 22, 2011, 04:15 PM
Aby@MIL.SPEC's Avatar
do yourself a favor, get yourself a map sensor, o2 sensor & ait wired in & have fun. rre or speed lelment have inexpensive map sensor adapters. you want that sensor mounted on the intake mani, not 4 or 8" away via some small boost line, othewise there is a pretty sizable boost signal delay.
what are your mods? maybe someone can shoot you a base map that they already have if the mods are similar.
Old Jun 22, 2011, 05:42 PM
n2oiroc's Avatar
i have a uego, 5 bar with adapter and ait waiting to go in, i just need time off of work. right now its bone stock down to the air filter, im just getting familiar with it before i slap my good motor in.
10:1 long rod 2.23L 4g64
headgames race head
custom gsc cams (274/274 236/236@1mm 12mm/11.7mm lift)
full race twinscroll t4 efr 8374
fic 2,150's
ets 4" ic
all the usual crap, etc.
Old Jun 23, 2011, 05:10 PM
^yeah, definately get those parts on there. dicking about with the maf is a waste of time.
do you know the wiring scheme for those sensors into the evo harness? if not, i will dig up my notes when i get home & post them here.
GL
Old Jun 23, 2011, 06:42 PM
n2oiroc's Avatar
GL
i dont have a diagram, if you can post them i would really appreciate it!
Quick Reply: just installed aem and the car wont start
