AEm 5 bar sensor issue?
Setup,sensors,map sensor wizard. Set it to 5 bar. Set your load units to psi, and it should read zero. If not, check wiring on the harness before the sensor. Also check the pressure connection area for leaks. if all thats good, then bad sensor
blowngasket
Feb 13, 2014 09:42 AM
