Aem ems 2
Aem ems 2
I have an AEM EMS 2 was wondering if it would pass a OBDII emissions inspection and if not what is a good ECU set up should I just go back to stock?
you will fail right away with anything currently other then the stock ecu i would stick with the stock ecu and just switch to speed density this will allow you to remove most of the emissions related equipment and still pass do you have emissions every two years or yearly there are guys that can remote tune you and get you up and running in no time.
ExtremeDSM
10
Sep 1, 2012 06:38 PM
