Lancer Evolution 7 AEM EMS Successfully Installed
I would like thank Frank from South Florida Performance for sucessfully installed and mapped my Evo7. I have no words to described the kind of person that he is. This guy is a very honest and straight forward person, it is very pleasant to have the oportunity to work with such a professional person.
My car is an Evo7 with a Tomei 2.2 Strocker kit with all the usual race stuff that goes along with it. For injectors, I'm running HKS1000cc.
He made me 2 maps, 1 for pump gas and 1 for C16.
The car pulls awesome at 1.5 on pump and at 2.0bar with C16, it is just something else. This system and his service, truly surspassed my expectations.
Once again, I would like to recomend Frank from SFP if you have a car that needs to be map or else.
AWESOME, AMAZING AND OUTSTADING SERVICE
Regards,
Enrique Thompson
Crazy4Cars Racing
Panama
Central America
Regards,
Enrique Thompson
Crazy4Cars Racing
Panama
Central America
Also, the basemap of the Evo 8 can be used on the Evo 7? Or is needed to create a specific basemap?
Here is what I was doing so far
Code:
=================================== [EVO VII - VIII PINOUT DIFFERENCES] =================================== -------------------------------- [Evo 7 pinout | AEM EMS 30-1313] -------------------------------- 8.Fuel pump relay 2 | A/C compressor relay 22.A/C compressor relay | Fuel pump relay 2 40.- | MAF Ground 43.- | Clutch Pedal SW 46.- | Fuel Pump IN 53.SAS Selenoid | - 55.I/C Spray Relay | EVAP Emision vent 56.Diagnostic | - 57.-|H2O Spray Relay 61.-|Fuel tank diff press 73.-|Manifold differential press sensor 74.-|Fuel level IN 77.-|Fuel Temp IN 87.ACD/AYC Signal IN | - ------------------ [Posible rewiring] ------------------ 8-22.Fuel pump relay 2 | Fuel pump relay 2 22-8.A/C compressor relay | A/C compressor relay 55-57.I/C Spray Relay | H2O Spray Relay
@wreckleford thanks, Already did the changes on the AEM
And, will and Evo 8 basemap work to startup the Evo 7 before getting it tuned, do you have one so I can check it? And, Is it better to get a map sensor or with the MAF it will work fine?
cij911
Nov 16, 2010 12:38 PM
evoixbri
May 12, 2010 03:22 PM
gl4662
Automotosports - Illinois
Oct 9, 2006 02:11 PM
