Accelerator pump function?
Hey guys,
I get a "lean bump" every time I lay into the throttle. I know it isn't a problem with the maps because it is not RPM dependent, it happens wherever I happen to go WOT. I need to know how to set up the accelerator pump function correctly.
Thanks for any help,
Keith
Keith
lower the dtps trigger to 1 and raise the sensitivity to about 90%, normally a sustain of 5-10% works good. if you still have problems start raising the accel limit by a few % and testing till you get it right.
if you right click on the parameter O2#1 and view it as a scope that will help you see whats going on better.
Toxzon
Jul 30, 2017 08:30 AM
Toxzon
Jun 5, 2017 07:25 PM
accel, acceleration, accelerator, accellorator, accerator, aem, aemaccelpump, ems, evo, function, pump, role, sensitivity, stand, tuning
