AEM EMS Get tuning help for your AEM EMS system.
knock count
Old Apr 20, 2004 | 09:46 PM
EVOMIZ's Avatar
knock count
anyone know how to setup the knock count activity?
i have a knock link in the car and it is lighting up and i get no knock count when i log on the aem.
is me knock link lieing or am i getting knock?
the car was tuned on a dyno with 94 pump gas with no knock at all (on the knock link) but when i was on the way (93 octane) home the knock link was lighting up and still is.
Old Apr 21, 2004 | 08:59 PM
Wadzii's Avatar
goto setup_sensors_knock sensor_knock sensor control
that will bring up a parameters screen and a table. thats the knock sensor cal table....
now you need to use the data logger... log knock #1 volts set to log fastest.
log a pull from idle to redline under low load with race gas and conservitive timing. look at the log of knock volts, this will give you a "picture" of the natural noise of the engine. simply make the knock sensor cal table match the numbers you got from the logs, add a couple tenths of a volt just so you dont get any retard from "fake" knock (ie, loud engine noises, the wg opening etc).
click the box that says knock control in the top right of the screen. the other settings should be fine.
Old Apr 22, 2004 | 07:56 AM
EVOMIZ's Avatar
Thanks I will give it a shot
Old May 2, 2004 | 02:19 PM
Guido's Avatar
yea should work
mshilto89
Cobb AccessPORT
Feb 28, 2013 11:12 AM
deadstockkpomp
Jul 8, 2012 04:06 PM
DCsleeper
May 7, 2008 02:14 PM
sponners
Apr 30, 2008 03:45 PM
cij911
Aug 7, 2007 05:42 AM
