Anti-Lag build Thread
Most Recent Update: 7/27/12!! Dyno Tuning Video and Results!! First Post on Page One!
NEW BUILD THREAD HERE DUE TO VERY LONG THREAD Quest for 9 Second Stock Turbo
Hey guys, im Tyler im currently building my Evo 9 RS nickname Anti-Lag into a Full drag car im hoping to obtain the stock turbo record with. That is the goal at least. Some history on the car is it was previously Kunal's car (aka Kuniiizzzeee dial-in) cant thank him enough for a more prestine 9rs and all the help over the past couple months. One of my best friends as well as most influential people in putting this build together. As well as Brian and Emery at STM for all the suggestions and help into building this car. Also like to thank Adam at DynoTech for all the help and look forward to building this custom turn down.
The car is on SD.
Goals with the car is 9.99 on the stock turbo.
WHP:454 WTQ:451 (Mustang Dyno)
Weight:2XXX
Build not finished yet.
http://www.youtube.com/watch?v=P6xus...layer_embedded
Sponsors On Board Who I Cant Thank Enough
DynoTech Tuning
AngryAero
STM
ToxicFab
Big Thanks to:
AngryAero - Jason (AngryEvo8)
Kunal Mahajan (Kuniiizzzeee)
STM (Brian, Cory, and Emery and everyone else)
[B]Adam @ DynoTech
Jamie & Brian @ DynoTech
Collin and BJ @ ToxicFab
Also if anyone wants to see other parts run or tested, ill be willing to post results after i finish my build. Ill see if i can get my hands on them to borrow from friends or purchase. Have a couple tests i want to run as well. One being I will be doing a full tune on AEM and a full tune on the Stock ECU and comparing the differences. Also want to make a FF manifold for the turbo as well. LMK what you might like to see. like i said it wont be done till after the car is built and raced, but more than happy to try different parts and post results after i reach the record!
Mod List
Engine:
BR 2.0 LR Aluminum Rod Motor
ToxicFab forward facing Manifold
ToxicFab 02 housing for FF manifold
ToxicFab Custom LICP for FF Manifold
BR Full TBE V-Band/ToxicFab Turndown
ToxicFab 4.5 FMIC
BR 65mm TB
STM Ported and Coated IM
STM UICP
Tial Q BOV
Spoolin UP COP
Hallman MBC
GSC S3
Supertech dual valve spring and retainers
ARP L19
STM Oil Catch Can
STM Coolant Overflow Can
SS Valve Cover Bolts
Zeitronix 5 bar MAP
A/C Delete
PS Delete
STM Oil Cooler Delete Kit
STM Small Battery Kit
STM Small Radiator
Gates Timingbelt
Ported Head by ????
Fuel:
2 Walbro 255 Modified
BR Double Pumper
AMS Fuel Rail
AMS Fuel Rail Feed Line
FIC 2150cc injectos
Drivetrain:
Shep Trans evo 8 3 & 4
Shep Built Non ACD Tcase With RS LSD
Exedy Twin HD
STM Clutch Fork Stop
AWD Driveshaft
Torque Solution Driveshaft Bushings
Avid Motor Mounts
SS Clutch Lines
BR Underhood Shifter Bushings
Torque Solution Base Shifter Bushings
Suspension:
Front and Rear Sway Bar Removed
AWD D2
BR Side Diff Support
BR Mustache Bar
BR Center Member
Whiteline Bushings
Interior:
Sparco Sprint 5 Racing Seat
Sparco Racing Harness
Sparco Harness Bar
Tires/Brakes:
M&T 26.5x8.5x15 Slick
20mm spacers
15" Rota Slipstream Black
STM Front Drag Brake Kit
SS Brake lines Front and Rear
No ABS (RS)
Aero:
BR Front Undertray
BR Rear Undertray
Mitsubishi Vortex Generator
Side Mirror, Front Facial Block off Plates, and Bumper Shutters Courtesy AngryAero (Jason Thanks for the help bud!)
Appearance:
Carbon Fiber Radiator Cooling Plate
STM Radiator Brackets
Tuning
Stock ECU
Spoolin UP SD Harness
GM IAT Sensor
E85
Probably more that im forgetting but thats a good bit for now.
Please Keep all negative comments to yourself. Especially ppl who want to comment on hacking up the car or pulling out the interior for records. Now some pictures LMK your thoughts. Weekly updates will be provided! Enjoy
Links to ToxicFab Manifolds Website link in signature:
ToxicFab Parts
https://www.evolutionm.net/forums/ve...umps-more.html
ToxicFab Stock Frame FF Manifolds (Manifold i will be running with a couple extra options)
https://www.evolutionm.net/forums/ev...-manifold.html
Link to thread!
NEW TOXICFAB PRODUCT!!! Bumper Latch Kit!!!
https://www.evolutionm.net/forums/ve...latch-kit.html
The car is on SD.
Weight:2XXX
DynoTech Tuning
AngryAero
STM
ToxicFab
Big Thanks to:
[B]Adam @ DynoTech
Mod List
Engine:
ToxicFab 4.5 FMIC
BR 65mm TB
STM UICP
Tial Q BOV
Spoolin UP COP
Hallman MBC
GSC S3
ARP L19
STM Oil Catch Can
Zeitronix 5 bar MAP
A/C Delete
PS Delete
STM Small Radiator
Gates Timingbelt
Ported Head by ????
Fuel:
BR Double Pumper
AMS Fuel Rail
FIC 2150cc injectos
Drivetrain:
Exedy Twin HD
AWD Driveshaft
Avid Motor Mounts
SS Clutch Lines
Suspension:
AWD D2
BR Mustache Bar
BR Center Member
Whiteline Bushings
Interior:
Sparco Harness Bar
Tires/Brakes:
20mm spacers
No ABS (RS)
Aero:
BR Front Undertray
BR Rear Undertray
Appearance:
Tuning
Stock ECU
GM IAT Sensor
E85
ToxicFab Parts
Link to thread!
Honestly stock turbo is the first goal im going for. then stock block, and then fastest evo period. thats the goals for this car.
And yes stock block for now. it will be a stock block untill i get the records im after or the block lets go. After that youll have to wait and see. I have a few ideas.
Thanks i appreciate the support. and honestly the stock turbo is the starting point as id like to break into the industry one day in anyway possible. Ive been in the car industry since i was 15. this is what i love most in life besides family and friends. Im hoping to turn a dream into reality. Thanks for the support.
Thanks guys i appreciate the support. Ill have more pics up tomorrow, i dont have a good camera so ull have to deal with my ****ty pics for now. Im hoping to be the first stock 9 turbo in the 9s more than anything else. Then its time for a change. Ill keep u updated! Good luck with your car, lmk if you have any questions, more than willing to help or give advice. feel free to post pics.
Cant really tell you my boost and etc. But yes stock turbo no porting etc. Youll have to wait for the thread where i reach the goal. Im a good driver. my old evo i went 11.4 @ 116 LIFT shifting on street tires with belts showing. this one will have anti-lag on the line, NLTS, slicks all 4 corners, etc. I know it is capable of the goals. But boost will be 30+psi. ill keep u posted. pm me if you want more info.
^ ill keep you posted. Wont be ready till spring, but when it is ready it will be all out effort! I will post tuning graphs, time slips, etc when i start running in spring. What have you been running with that 2.4?
