FS: avo fuel cut defender and bov
well as it states i got an avo bov for sale askin 200 for it
also got an avo fuel cut defender/override for sale askin also 200 for it
both off my evo so yeh...
How does the fuel cut defender work?
Does it alter the MAF sensor readings to the ECU?
I need a fuel cut defender that still allows me to use a piggy back.
Originally posted by tenji
think it just bypasses the fuel cut limit for the ecu...so u dont get any fuel cut wen running high boost
Yeah, it overides the fuel lcut limit on the ECU, and allows boost to be increased..
The Turbosmart version is really good, a few guys here use it, and the AVO as well..
I take it you have changed or planning on changing your injectors and fuel pump Sunder?
basically works the same as a boost bleed valve..
I'm completely lost, with MRT trying to tell me that I need a full replacement ECU to change my fuel cut, and Power Digger telling me I can do it with the piggy back, and yet others, telling me I can use a Fuel Cut Remover.
So I need to get this sorted out before I spend any money, I think.
MMLVMM
121
Sep 21, 2003 04:35 PM
