AMS Help! Engine diagnosis wanted before appointment
AMS Guys-
I am thinking I need to make an appointment to have my car checked out with you after I had it at the strip this past weekend. I was wondering if you could take a look at this video I made of the issue where it limps for a second around 40000 RPM when I go into WOT. I am thinking it is either the plugs as opposed to a boost leak.
http://www.youtube.com/watch?v=HDj7q4nVoFM
You can see how the RPM dips down a second then back up when I try to quickly accelerate. If I accelerate slowly I do not run into this issue at all. Hopefully you guys can let me know what I can do prior to taking it to you for a further inspection. Any help would be appreciated. Thanks!
Are you running a stock turbo and pump gas? That is a lot of boost for a stock turbo on pump.
For me, the video does not give me enough information to lean towards any specific issue. Please call the shop and get on the schedule so we can take a look and get your issue sorted out.
AMS Guys-
Eric
Sounds like the clutch slips for a second then grabs. Do a pull in a higher gear I think you'll find more slip. Bend over and hike the wallet.
Juat a few things in response to everyone since I was at work all day and couldn't respond:
1. A 2-step has been performed on the car a total of 5 times. 3 a while back to practice, and twice at the track during my first two runs. The last two runs were done without it.
2. I am definitley not pressing down all the way on the gas, but I do slowly push more to accelerate over 3000 RPM and it does it's limp thing around 15 psi and then continues on so I have not tried to fly forward in any certain gear. At this point I am not even going to attempt to test the thing anymore until it is inspected and have rarely even gone over 5 psi of boost on the road.
3. The RPM's defintley just dip down a second as opposed to revving up, which is why I did not think it was the clutch. The car has a little over 23K miles on the stock clutch and stock turbo. So far I have put about 14K miles on it since I purchased it with 9K and have babied it up until this weekend really since it is my daily driver to and from work every day.
4. The car had the BCS modified by AMS to allow for more boost when I had the downpipe and fuel pump installed there, so there is no MBC in there currently. I know Autometers tend to read high so I do not think I am actually running as much boost as it says. In 5th gear in high RPM's it says 25 psi but that is the only time it really ever gets that high is in that gear.
I have already booked an appointment with AMS as soon as they open next Monday and I will post what the final results are...hopefully not an expensive one! Thanks for everyone's feedback and for AMS getting me set up for inspection.
could very well be plugs, had a 2G car on c-16 stop in its tracks when it would go into load and wouldnt go over 7psi because of plugs, swaped them out, ran 30psi just fine. But that is c-16 eats stuff up after a while. just might be it..
