Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Where are all the AMS 50trims????
Old May 14, 2007 | 01:38 PM
  #31
BenjyJ's Avatar
Originally Posted by wroblewskievo
my 50 trim 2.0 is going into ams this wednesday 5/16/2007 for a aem ems install and tune for 93 oct and 100 oct. on just 93 oct the car only dyno'd at 390 hp 320 tq. that is why i switched to the aem because it was way low on power. the first tune on the stock ecu couldn't take anymore boost or timing. hopefully the ems and 100 oct help that. i'll post the results when i get it back.
niiiice.
Charlie at topsetup was tellin me about your car last time i was in there, apparently it sits almost identical to mine.
I want ems bad
Old May 14, 2007 | 09:07 PM
  #32
Ludikraut's Avatar
Originally Posted by High_PSI
This may be the next evolution in Turbo kits. With a Twin scroll it'll make a world of difference. Look at how successful the Green is, VERY VERY VERY fast spool, stock like drivability, and 10 Second 1/4 mile runs. It is quite massive achievement for only $1000. I can't see myself dumping $4000 into a turbo kit anymore, I just can't.
All depends on what you ultimately want to do with your car. I agree that the FP Green is probably the best street setup right now, but my 50 trim setup is just phenomenal for road racing.
l8r)
Old May 14, 2007 | 10:29 PM
  #33
scorke's Avatar
You also can't see yourself making 450 whp on pump or 500+ on race gas on the green either
Scorke
Old May 15, 2007 | 09:49 AM
  #34
MO_EVO8's Avatar
^^^^^^^dido......50trim>green........^^^^^^^^
Bottom line is do you want more power or not.
Old May 15, 2007 | 10:37 AM
  #35
High_PSI's Avatar
Scorke
Very True, but you won't make 470 Foot Pounds on a 50 Trim while the Green Does. As Dave B always say, it's the power under the curve. The spoolup is superior and so is the torque it so therefore I would say that the FP Green is a superior 1/4 mile turbo Vs. a 50Trim Turbo Kit.
Old May 15, 2007 | 03:20 PM
  #36
MO_EVO8's Avatar
^^^^^^^^ will see ^^^^^^^^^
Old May 16, 2007 | 10:04 AM
  #37
ace_2822's Avatar
What kind of torque #s would a 2.3/50 trim produce?
Old May 16, 2007 | 10:16 AM
  #38
scorke's Avatar
50 Trim shouldn't have too much trouble.
I made 480 ftlbs of tq with my 30R.........
The Green should get smashed by any good 50 trim setup on the street because the Green cannot flow the sort of air up top that a 50 trim can. A 50 trim will be laggier and not as torquey as a Green down low but up top it should dominate.
Scorke
Old May 16, 2007 | 10:21 AM
  #39
Blue Evo 8's Avatar
Scorke
I cant believe you just said that....watch out the FP fanboys are coming!!!!
  #40
scorke's Avatar
Originally Posted by slow8
Mods are:
I have AMS' 50 trim w .67 a/r
2.3 L stoker
AMS VSR
Ams fuel rail w AMs 680's and walbro 255
AMS FMIC
AMS 3' tbe
hks 272's
fidanza gears
greddy type S
AMS UICP & LICP
AMS RAce Battery
Shep trans and transfer case
Exedy twin
AMS water injection
ON 93 octane and meth it put down 497 awhp 460 tq
Theres 500 whp and 460 tq out of a 50 trim, which is good if you ask me.
Also, are your sure your not just nutswining the green for some reason now because you used to be a big fan of the 50...
I can't think of a better turbo kit then the 50Trim for the stock 2.0. It is perfectly matched and does not exceed the whp limit and can get you deep into the 11's and someone with a NON BB 50Trim just ran some 10's on Pump/Meth. Very nice kit.
What I like most about it is you can run a solid 23-24PSI on it pump gas and it is SOOOOOO efficient it'll hold that boost till redline no problem and not be nearly as hot as the stock turbo.
I want one badly
Scorke
Old May 16, 2007 | 10:23 AM
  #41
scorke's Avatar
I can take them on.
They are two different turbo's with very similar peak flow numbers.
50 lbs per minute, one that serves it up very quickly and relatively cheaply, but gets inefficient up top, one that is laggier and more costly thats much better in the upper RPM ranges...
They are similar but achieve two different goals IMHO.
Scorke
Old May 16, 2007 | 10:31 AM
  #42
ace_2822's Avatar
Thats so true!
Old May 16, 2007 | 11:10 AM
  #43
Ludikraut's Avatar
This would only be true if the 50 trim can rev high enough to take advantage of that power. On pump gas that means being able to rev out to between 8500 and 9000 RPM. If you're still talking stock internals, then the FP Green will have the better powerband.
l8r)
Old May 16, 2007 | 11:16 AM
  #44
scorke's Avatar
Ludi have you seen the TQ drop off on the green's? FWIW i'd much rather have less peak tq and have it carry to redline without dropping than have a huge spike early on.
This is my main motivation for going from a 30R to a 35R, not so much the added top end HP but the added tq. Making my move I will effectively bump the entire powerband to the right, however in doing so my HP will climb to redline and TQ will carry further at the expense of response and spool, which with my 2.3 I don't mind doing.
Scorke
Old May 16, 2007 | 11:20 AM
  #45
scorke's Avatar
Here is a sheet of the most powerful/tqy Green to date. See the peak/drop off? That's why I am saying the 50 trim is superior if you are worried about power after 5k, vs the Green is a sick turbo down low. He loses 200 ft lbs from peak to redline and about 70whp while most built 50 trim's lose far less at the expense of revs.
My 30R made 20 more hp and 10 more ft lbs of tq at 5 psi less than what this guy used to make these numbers on his green, and was only marginally laggier.
Scorke
Quick Reply: Where are all the AMS 50trims????
