*NEW AMS PRODUCT* AMS 2.3RR Engine Release
#46
then again it does require a custom headgasket and would be priced for a sleeved block.
94mm stroke and 87.5 piston is 2.260...closest I can get it without doing completely custom crank and or .25mm increments on the bore.
#47
Ted is correct and I'll leave the exact #'s out for now. Obviously the rods are longer which moves the pin up and takes weight out of the piston. If stroke is shorted, then yes the bore is bigger to make up the displacement. The actual displacement is 2260cc's so it's little smaller than the std. 100mm stroker. Well ok, I'll give one exact number out
The rod ratio is actually higher than stock and the piston speeds come down because of two factors, stroke, and rod length. Using software, I've figured about a 160-180RPM gain just from the reduced G's because of the rod length.
Here, read this
https://www.evolutionm.net/features/article.php?id=77
There is some good info on the basics.
Here, read this
#48
very interesting...seems similar to a motor I've designed (haven't built) but only have a RR of 1.64 in a 4g63 block...also 2260cc's...now I'm quite curious.
I've done the same principles with my subie engine...almost an EJ257's displacement but with a much more favorable, high rpm rod ratio and better discharge coefficients..also more room for deshrouding the valves.
Based on matching absolute max acceleration (as spreadsheet refers to atdc as "-") I gain 300-330 rpm pending on how high redline is set.
I'm quite interested to see how the RR motor will do in customer hands!!
-Micah
-Micah
#53
I still find it funny that martin posted "no dimensions will be mentioned" directly under my formula to get a suspiciously close shortblock
#60
i guess i'm a little confused on the HTA turbo, the compressor cover we use has a 4" inlet with a 2.5" outlet also, and the newer style compressor covers have the surge-port inlet extend (smooth bellmouth) to the cover inlet. Not sure there is really any difference, and unless someone has tested the variation of 35r we use against the turbo buschur calls the HTA35R, then you really can't give any subjective opinion on it.
The 37r (67ptrim) is capable of 700-720whp, while the 35r is capable of 630-650whp, so you're looking at roughly 50-70whp gain.
