Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
*NEW AMS PRODUCT* AMS 2.3RR Engine Release
Old Jan 26, 2008 | 11:31 PM
  #76
BluByYouEvoVIII's Avatar
What is the wait time for this motor? How long has everyone had to wait after placing the order until arrival?
Old Jan 29, 2008 | 03:43 AM
  #77
dxbevo9's Avatar
bump?
Old Jan 29, 2008 | 08:10 AM
  #78
AutoMotoSports's Avatar
Typical build time from order to shipment is about 3-4 weeks. If order start picking up that will get drawn down as we will build some for stock.
Eric
Old Feb 5, 2008 | 11:19 PM
  #79
You will be getting my order in 1-2weeks. Cant wait to get my hands on this amazing engine. Great job on this motor guys!
Old Jun 26, 2009 | 09:33 PM
  #80
SWOLN's Avatar
Was the rod ratio ever disclosed since the release of the motor ?
Old Jun 29, 2009 | 08:00 AM
  #81
homemade wrx's Avatar
Originally Posted by homemade wrx
...then again it does require a custom headgasket and would be priced for a sleeved block.
94mm stroke and 87.5 piston is 2.260...closest I can get it without doing completely custom crank and or .25mm increments on the bore.
Originally Posted by AMS
I'll leave the exact #'s out for now. Obviously the rods are longer which moves the pin up and takes weight out of the piston. If stroke is shorted, then yes the bore is bigger to make up the displacement. The actual displacement is 2260cc's so it's little smaller than the std. 100mm stroker. Well ok, I'll give one exact number out
The rod ratio is actually higher than stock and the piston speeds come down because of two factors, stroke, and rod length. Using software, I've figured about a 160-180RPM gain just from the reduced G's because of the rod length.
very interesting...seems similar to a motor I've designed (haven't built) but only have a RR of 1.64 in a 4g63 block...also 2260cc's...now I'm quite curious.
-Micah
= a 4G64 block with 87.5mm piston and 94mm crank. If using the same compression height of a 100mm stroker piston; you'd be around a 1.7:1 with a nearly 160mm rod...these are just off the top of my head and what I recall dimensions as being. I'm a subie guy without numbers in front of me, so please forgive me for tossing out some numbers I did about 2 years ago.
See above
If you take bit more comp height you will be over factory rod ratio. You could also use a smaller pin diameter too...21mm pin = .5mm longer rod.
Double checking numbers...
150mm is stock rod
4G64 block is 6mm taller than 4G63
CH from a stroker piston is about 6.3mm shorter IIRC
94mm crank is 6mm longer than factory
150mm + 6mm + 6.3mm - (6mm/2) = 159.3mm rod
Sometime I really wish I had been chosen for one of those AMS former FSAE engineering jobs.
Old Jun 29, 2009 | 09:12 AM
  #82
evoracingstar's Avatar
bad@$$ now if i had the money!
Old Jun 29, 2009 | 09:48 AM
  #83
SWOLN's Avatar
See above
150mm is stock rod
Hey ! You're a good detective. I totally missed the underlined part in the AMS post. Thanks !
Old Jun 29, 2009 | 01:16 PM
  #84
yeah, well it was really ironic as I had designed a very similar block for my friends evo 8 before this platform was released. However we were keeping the 4G63 block and the only two differences are block ehight and thus rod length...
...that I know of.
But he decided he'd rather stroke it and run a short rod. It is sitting with a sleeved 4G63 2.4L now.
Old Jul 9, 2009 | 09:08 AM
  #85
11secEVO7's Avatar
this is the greatest motor ever..
My car put down 700+awhp with this motor recently...
it's pricey..but worth it !
Old Jul 9, 2009 | 02:55 PM
  #86
wspy's Avatar
Horaaatioooo!!
Old Jul 9, 2009 | 03:58 PM
  #87
tumtum411's Avatar
bump for ams performance i know a few pplz that want this motor good r and d
Old Jul 10, 2009 | 06:32 AM
  #88
rio-evo's Avatar
Hi, is that the price for the engine installed or just the engine?
Thanks,
Old Jul 10, 2009 | 09:43 AM
  #89
SWOLN's Avatar
Thanks,
Just the engine.
Old Jul 14, 2009 | 09:43 AM
  #90
11secEVO7's Avatar
Originally Posted by wspy
Horaaatioooo!!
hahaha yup...Horatio is right...great great tuner I must say..very impressed with his work..
so what's the latest spy...still have the evo 7?
R/TErnie
80
Jan 7, 2021 03:46 PM
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 11, 2016 09:15 PM
Shaun@AWDMotorsports
Evo 'For Sale' Engine Internals and Drivetrain
206
Feb 6, 2016 06:36 PM
AWD Motorsports
AWD Motorsports - Florida
15
Aug 24, 2010 03:38 PM
AMS
145
Aug 2, 2007 10:07 AM
Quick Reply: *NEW AMS PRODUCT* AMS 2.3RR Engine Release
