AMS Suspension Stages Release!
As most of you that have been following us may know we have spent alot of time these past couple of seasons developing our time attack cars. Along side the development of our two time attack cars we have really learned the inn's and out's of the evo chassis and suspension layout. We are taking that knowledge and applying it to some suspension stages that we will be releasing here in the coming months. The first two are available now.
AMS Suspension Package Stage 0 (SP0)
text by Martin Musial
AMS Suspension Stage 0 or SP0
This is a basic starter point in suspension upgrades. This package will utilize your factory Struts and springs and improve handling via an improved alignment and a whiteline bump steer correction kit
Alignment Front Toe: zero to 1/16” toe out Camber: -1.5 to -2.0 Deg negative camber (via offset bolt on strut to spindle mount) Rear Toe: zero to 1/16” toe in Camber: -1.0 deg negative camber
Whiteline rear bump steer kit:
This will help eliminate some of the understeer the EVO exhibits on mid corner and corner EXIT. The rear geometry promotes toe-in under compression and max compression takes place at mid corner and corner EXIT, just where the EVO tend to under steer. The rear bump steer correction kit lets the rear toe geometry stay neutral instead of going to toe-in under compression, letting the rear of the car move a little easier under mid corner & exit throttle conditions. Please be aware that toe out on the front will let the car wander a little on the road.
$62.46
click here to purchase the SP0 Kit
AMS Suspension package Stage 1 (SP1)
The AMS Suspension SP1 is designged to maximize your factory suspension without replacing the Stock springs or struts. This package will require an alignment after installing these components.
SP 1
-Whiteline front Roll Center Adjust kit (Car must be aligned after installation of RCA kit)
-AMS Rear Trailing arm bushings
-Whiteline front control arm bushings W0593
-Whiteline Rear Sway bar 22mm adjustable (Optional 24mm adjustable)
-Optional Whiteline rear heady duty sway bar end links (adjustable to eliminate sway bar pre-load)
-The Car must be aligned after installation of roll center adjust kit
max negative camber (-1.9 to -2.0deg) via front camber bolts
-Optional Noltec front camber plates (From -2.0 to -2.5 deg track/street, or -3 to -3.5deg for track use)
The RCA kit helps the camber curve under compression. The front end loses camber under compression because of the angle of the control arm and the RCA kit also changes the roll center to help handling. The camber plates allow more negative camber which adds to front grip. The rear sway bar increases rate of load transfer on the rear, increases roll resistance, and will allow the rear of the car to move a little more under cornering. The HD adjustable sway bar end links are an option but are recommended to ensure there is no sway bar pre-load. The rear sway bar is adjustable to change the balance of the car to the users preference. The SP 1 package will be great even for beginners who can explore the limits of the car without the dangers of snappy & twitchy handling.
$549.95
$157.28 Extra for whiteline adjustable sway bar endlinks
$369.95 Extra for Noltec Front camber plates
click here to purchase the SP1 Kit
Eric
$62.46
SP 1
$549.95
Eric
Sounds like a carefully thought out and well designed set of options.
Will there be a specific option for those of us running springs -- such as the swifts?
Is this a precursor to the full AMS coil-over setup?
goofygrin
88
Jul 24, 2022 08:22 PM
DSG Performance
EvoX 'For Sale' Suspension / Brakes / Handling
11
Nov 27, 2015 09:28 AM
500whp.com
23
May 26, 2005 07:01 AM
