Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS Manifold & Upper Radiator Hose solution?
Old Sep 25, 2007, 12:52 PM
GTVEVO's Avatar
Anyone have one, right now I am running the slip over heat cover but I don't think it is going to last long as it is showing alittle bit of burning. I was wondering if there is someone who has a upper radiator hose option that can withstand the heat in silicone or aluminum for sale? Just figured I would ask to see what everyone else did before I come up with my own solution.
Old Sep 25, 2007, 02:08 PM
jbergmeier's Avatar
i never had a problem with mine, are you sure your radiator is not out of place, or the car ever have front end damage. it should not be touching the exhuast manifold, but close.
Old Sep 25, 2007, 02:15 PM
GTVEVO's Avatar
I bought the car new, it has never had any frontend damage of any sort, I am running a koyo rad which is a bit thicker I believe. Its not that what they supplied woudln't work for while probably, it doesn't touch just very close. I am wondering if there is somthing better becuase I wouldn't think that everyone running an AMS kit is using only the one little piece.
Old Sep 25, 2007, 05:23 PM
ProccoEVO's Avatar
here's what I did when I custom got made my old GT35R top mount set up
is a evo 6 koyo radiator and you can use a streight hose
Old Sep 25, 2007, 05:49 PM
whitey4d's Avatar
Did u ever trim the hose shorter? Ivan from AMS said to cut about 1/2 an inch off the hose to help pull it straighter and away from the manifold.
Old Sep 25, 2007, 06:20 PM
GTVEVO's Avatar
Both seems like reasonable solutions so thanks.
Procco, who made the upper radiator pipe for you?
Old Sep 25, 2007, 07:16 PM
thatsMR2u's Avatar
though a straight metal line from the radiator to the thermostat housing seems like the best route- motor shifting will lead cracked pipes- theres a reason why our stock line has zig zags
Old Sep 25, 2007, 07:30 PM
jbergmeier's Avatar
I had a koyo to, thicker than stock, didnt have any melting problems, i didnt have a coated header eather... so it must be very very close
Old Sep 25, 2007, 07:40 PM
rocket900rr's Avatar
I used exhaust/header tape from NAPA. Seems to do the job.
Old Sep 25, 2007, 08:15 PM
midwestmonster's Avatar
ETS makes a metal replacement pipe.
Old Sep 26, 2007, 06:11 AM
GTVEVO's Avatar
Below are some pics of mine, I have not trimmed the upper rad hose and if this is what AMS recommends I think it might work. I would like to contact and see ETS's hard pipe solution. You will notice in my pics that it isn't touching but it is very close so it is touching at times I would suspect. Nothing has melted, just trying to be proactive.
Old Sep 26, 2007, 06:13 AM
GTVEVO's Avatar
Does ETS have a website or any pics posted on here?
Old Sep 26, 2007, 06:56 AM
PVD04's Avatar
I also recall reading a post from AMS where they recommended cutting about 1" off the radiator hose to pull it away from the manifold. It looks as though that would help a lot.
-Paul
Old Sep 26, 2007, 06:59 AM
PVD04's Avatar
I also wanted to note, the stock line has zig zags to avoid the intake snorkel, not for engine movement. I straight flexible line will allow for engine movement, as will a straight metal line with silicone connectors at each end.
-Paul
Old Sep 26, 2007, 07:43 AM
jbergmeier's Avatar
O ya i forgot i trimmed mine, yes you have to cut like 1" off the radiator end. i didnt have any problems with it. that is very close your problem will be solved after you trim it
Quick Reply: AMS Manifold & Upper Radiator Hose solution?
