Question to AMS engineer : 2.0L vs 2.3L
#31
You guys need to start a thread on VE . This is basically the area that seems to be misunderstood. With a better understanding of what VE is and how it is affected in a turbo engine you would have a better understanding of the differences of 2.0/2.3 as it applies to the 4g63.
It may be a good education for everyone.
#32
one thing most of you missed but JordanS4 began to hit on is the additional losses on a 2.3.
Think about it, with a longer stroke the 2.3 has to move the piston further - additional friction. At the same RPM the 2.3 piston has to move faster to cover the longer distance in one rotation of the crank. At a faster speed the piston in the 2.3 has more momentum (mass x velocity). It requires more force to stop the piston and reverse its direction. This is offset by the additional fuel and air afforded, but begin to add up as you increase RPM. This is not a linear curve.
At the higher RPMs the forces increase, as well as the friction causing a point where the HP of the 2.3 is matched by the 2.0.
#33
Martin is in CA right now. Ivan would be a better person to help you understand all of this in some more simple terms. I have the answers but with stuff like this I suck at getting them on paper.
I will ask Ivan to come in here tonight and I bet he can get you on track
Eric
Eric
#34
You guys are overthinking this.
1.) I'd be willing to bet that there are some critical missing facts in the posted link to the 2.3 vs. 2.0 comparison
2.) The main reason that drag Evos use the 2.0 instead of a 2.3 is because of the stock gearing - nobody wants to shift into 5th at the end, so you really want the extra RPM that the 2.0 can supply.
If you look at it from a torque/horsepower perspective, it's the same thing. A 2.3L may make 450 ft/lbs of torque to 7500 RPM, where a 2.0 may make 400 ft/lbs or torque out to 9000 RPM. 450 @ 7500 is 642 HP - 400 @ 9000 is 685 HP
When comparing a 2.3 against a 2.0 you also have to keep in mind the turbo, VE, and boost. For example:
2.3L, 100% VE, 28 psi at 7500 RPM will move ~62 lb/min of air.
By comparison:
2.0L, 100% VE, 28 psi at 7500 RPM will move ~54 lb/min of air.
So, what can we conclude? At the same RPM and VE, the 2.3L should make more power than a 2.0L ... given the same boost/if the turbo can move enough air.
HTH...
l8r)
By comparison:
HTH...
l8r)
#35
i agree that on paper the 2.3 should make more power for a given rpm,boost with no restrictions in VE between the two.
is this what we are seeing repated in reality?
or are those said mechanical losses at higher rpm of the 2.3 really robbing significant power?
unfortunately, most of real world results can't be compared accurately since too many variables exist.
guess we'll have to go with the paper
#36
By comparison:
HTH...
l8r)
By comparison:
HTH...
l8r)
#37
i know you guys are just trying to indicate an engine running at it's maximum efficiency by saying 100% VE, but remember force inducted engines regularly see VE's greater than 100.
off topic, but wouldn't another major advantage of 2.0 over 2.3 also be the faster rate of rpm increase? i would think less friction due to smaller rod angles, less momentum from lower piston velocity, and shorter piston distances for a single stroke all contribute to an easier and faster revving motor.
#40
l8r)
#41
Ok, here's the best comparison that I've been able to dig up so far. This pic combines test results from somewhat similar setups:
Runfile_009: Evo 9, AMS 2.3RR, AMS VSR intake, GSC S2 cams, GT35RL
Runfile_013: Evo 9, AMS 2.3RR, AMS VSR intake, GSC S1 cams, GT30R
Runfile_015: Evo 8, AMS blt 2.0L, AMS VSR intake, HKS 280 cams, 50 trim, AMS/Headgames ported head
All tuned by the same tuner (Chris) on 93 Octane, using AEM
All runs on the same dyno
All runs in 3rd gear
All runs SAE corrected
My personal conclusions from this:
1.) There is no point in running a 30R on a 2.3. The 35RL (yeah, it's not even an HTA) doesn't spool much slower than the 30R and absolutely buries it power-wise.
2.) There isn't much point to upgrading to a 2.3L if all you're going to run is a turbo in the 30R/50 trim range. Either engine will max the turbo out, and if you figure that a 2-3 shift at 8500 RPM puts you at ~6000 RPM in the next gear, you're really not gaining much with the 2.3. Yes, the 2.3 will out-muscle the 2.0 at lower RPM, but then I can rev the 2.0 even higher ... so it all comes down to a case-by-case basis: sometimes the 2.0 would be better, sometimes the 2.3
3.) This is a comparison of two heavily modded cars, with the 2.3 setup using the arguably best 2.3L kit out there. A more pedestrian 2.3 would fare worse in the comparison. Unfortunately I don't have a good dyno chart for a regular 2.3 that I can overlay...
l8r)
l8r)
#44
I know you asked AMS but i would hope that you know non of the highest HP cars are all 2.0 or destroked 2.1. Non are a stroked motor they just cant support the rpms that are needed for the size of the turbo to break 1100whp.
IMO i had a 2.0 then a 2.4 now back to a 2.0. Depending on your application i think the stroker motors are great. Lots of torque that is for sure. But if you think about how many rpms you are spooling a certain turbo faster then minus the rpms you are lossing on the top end becouse of the stroker it just doesnt seem to work out in the strokers favor. But im a drag racer other sports are different and the stroker would be better suited.
Chris
Chris
yeah but if you comparing at the same RPM the stroker will make more. the reason why 2.1 and 2.0l makes more cause they can rev and peak whp. The stroker is not safe to rev that high due to piston speed and rod angle like a 2.3. AMS 2.3RR is a 2.4 block with some customs stuffs. AMS correct me if i'm wrong. I'm going to buy AMS 2.3RR one of this day You'll get better rod angle just like 2.1 destroke, 2.4L with 2.0L crank and with long rod. rev that **** to the moon.
also i know don't why people call 2.4 a stroker. 2.4 is not a stroker. 2.4l is 2.4 block.
#45
That 1.5:1 rod ratio of the 2.3L and the added displacement will always give it faster spool and less top end power than the 2.0L
look at a comparison of the AMS 1000whp SCC article...notice the power and boost levels required between perrea's 2.3L and the shop long rod 2.1L...they are fairly similar setups but the shop car made 962@48psi and the 2.3 made 936 @52....10% (ish) less displacement and 4 fewer psi of pressure making 26 more hp...
now I'm just having fun(as I'm kinda tired at the moment and don't want to make a long response...that and I'm sure Martin can explain it to you as I think he too has a bit of a niche in IC engines engineering )....really the tests you list and the parameters shown can't really be compared to explain why the 2.0L is capping as fast as the 2.3L when it should be happier at high rpms (when compared to the 2.3).
