AMS piston ?
AMS piston ?
I was on your site earlier and please dont think I am trying to be rude or anything I just need some informational help. This is what your site says:
These AMS Spec pistons have a specially designed quench area that improves power and reduces the chance of detonation. All kits include special heavy-duty pistons, which are designed and manufactured to perform flawlessly under the extreme heat and PRESSURE associated with turbocharged engines. Ideal for both street and serious competition, these pistons are loaded with extra features such as annular pin hole grooves with double forced oil holes to prevent pinhole galling, and taper lands to prevent scuffing. Extra thick lands for superior ring groove support under extreme pressure are made possible by intersecting the ring groove and the pinhole. 4340 taper bore, hard-chromed extra heavy duty pins, along with Ross Racing Rings are included.
My question is do you guys do all this extra to the pistons? do they come like this? Is this a standard you ask Ross to make for you? Do these also come with retainers?
Also I seen that stock engine ratio is 9:1 right? I seen on Lancershop they have Ross 8:8 ratio so what is the difference. I am going with you guys anyways and I called up earlier to see if you had any in stock. I am confused and would love some help.
they are made per order from ross, I'm sure.
ross then also makes a standard piston that is just a drop in replacement...the aftermarket companies pistons are never as nice as a designated engine builders designed piston who has knowledge and cares about the best for the engine. I do the same with my JE subie pistons...
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
Brokenevo-
Tim did a lot of research and development with Ross so that they could specially make a great all around piston for street and strip that comes in complete kits containing the pistons, wrist pins, and rings. As far as retainers, Do you mean the retainer clips for the wrist pins? If so then yes, they are also included in the set. We try to make it as easy as possible so that anyone can buy the pistons and have everything they need to install them. Also the stock compression ratio for an Evo is 8:8:1 and our pistons are 8:9:1.
Please let us know if you need any further information.
Thanks
Thanks
Shaun@AWDMotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
110
Dec 6, 2016 04:52 PM
4g63girl
Oct 11, 2016 02:46 PM
