Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Ams Cnc Head - 140whp Gain!
Old Oct 23, 2008, 01:21 PM
Martin@AMS's Avatar
As you know our new AMS CNC head is working awesome. We have a few cars we built here that just putting down in the mid 500's on pump gas at 23-24psi on a safe tune, up considerably from our previous setups.
Now we had a chance to finally run the head on our drag car and got great results!
Previously our drag evo had a Cosworth head which has powered us to an 8.42 pass and a best MPH of 171 mph.
We put the car on the dyno and got baseline #'s at different boost levels with the Cosworth head. Next step was to put our CNC head on and again run the car at the same boost levels.
With the AEM in speed density mode anytime you make a change to the engine that improves or hurts the power it will change the fueling requirements. For example, a better flowing head will require more fueling so it won't run lean. In anticipation of the improved VE (volumetric Efficiency) I added a considerable amount of fuel in the high RPM range of the fuel map, and good thing I did! The first pull and I saw right away it needed the extra fuel, it still ran almost half a point leaner than it should have!
I dialed in the fuel a little closer and did another pull.
Here are the results at 46psi! The initial spike was 1psi higher and then dropped 1psi lower (i was still working on the boost feedback control) that's why the CNC head graph jumps up a bit and then dips back down. The gains where substantial everywhere. At 9000 RPM the AMS CNC head is making 140 whp more than the Cosworth CNC head!
All the work playing with valve jobs, porting, flow benches, and dyno testing has paid off.
Next boost level was 56psi dropping to 53psi. I really had to adjust the wastegate duty cycles to maintain the boost levels on our CNC head. The more air an engine can flow, the harder the turbo has to work to reach the same boost level. While we can run 35psi with a GT35 on a 4G63, put that same turbo on a big v8 and it would struggle to make 20psi. So here is the comparison of our CNC head and the Cosworth CNC head with the turbo being about maxed out (76mm compressor wheel).
Although not quite as big a difference as it was on the lower boost levels it's still making 60whp more at redline.
I'm really happy with the results and it once again prove what a great engine Mitsubishi gave us to work with.
-Martin
Old Oct 23, 2008, 01:25 PM
crazyevo4's Avatar
Graphs are not working.
Old Oct 23, 2008, 01:32 PM
Martin@AMS's Avatar
Links fixed!
Old Oct 23, 2008, 01:36 PM
SparkTech's Avatar
Simply Amazing...Excellent work
Old Oct 23, 2008, 01:41 PM
fimotorsports's Avatar
nice work!
Old Oct 23, 2008, 01:54 PM
Nez136's Avatar
Nice work Martin. I noticed on the first dyno plots of this CNC head that the mid range pickup shined as much as the top end on a more streetable setup (35r equipped). Do you think that the gains of a 35r equipped car at 35psi would see huge gains in the mid range as well?
The only reason I ask is b/c I dont want to add anymore lag to my setup (2.3 35r).
Old Oct 23, 2008, 02:07 PM
Martin@AMS's Avatar
What type of head do you have on your car now?
The 35R and 850R cars we've done here with our CNC heads have made really good power, I think your gains would be substantial, but again depending on what head you have on your car now.
-Martin
Old Oct 23, 2008, 02:17 PM
Nez136's Avatar
now your going to rip on me
Stock head with hks 272's, but still made 600whp on your dyno
I talk to loshak a decent amount and our dicussions usually consist of the next step for our cars. The conclusion always comes to sticking with the stock head b/c the gains aren't worth the money for a race head. But you seem to show otherwise.
I personally wouldn't mind a set of kelford 272's with this new CNC head. Im a guy who only gets to do a couple big things a year due to lack of income if you know what im talking about, so i try to justify every last cent for the power/performance im adding.
Old Oct 23, 2008, 02:41 PM
vboy425's Avatar
why are the graphs not in RPM ? also can you post graphs with whp and TQ
Old Oct 23, 2008, 03:30 PM
jbergmeier's Avatar
Martin what kind of gains you think this would do over my lightly ported stock head? and maybe change the VSR out with the F1 or Drag plentum?
Old Oct 23, 2008, 03:35 PM
Jasil's Avatar
Looks good!!
Old Oct 23, 2008, 03:55 PM
AutoMotoSports's Avatar
Martin can calculate torque for you if you like but we do not hook up the RPM pickup on the drag car. Shes pretty violent and the signal always cuts in and out or spikes. Its for this reason we just don't hook it up and use MPH on our drag car graphs.
Eric
Old Oct 26, 2008, 02:09 AM
socalmr's Avatar
i have a cosworth evo9 head with gt35, what kind of inc in power and torq could i honestly expect with the ams head?
Old Oct 26, 2008, 04:18 AM
Mellon Racing's Avatar
nice gains
Old Oct 26, 2008, 08:10 AM
Gold Sponsor
LancerShop.com's Avatar
what?
what?
Quick Reply: Ams Cnc Head - 140whp Gain!
