The AMS Genesis coupe is HERE!!! Let the modding BEGIN!!!
#321
As soon as you guys learn about a standalone, piggyback or reflash for 2.0T or 3.8, let us know!
#325
Here is the video about the dynojet CMD and Testing
http://www.youtube.com/watch?v=kvRJNW36yoM
Along with a few nice shots of the car.
#330
* Direct injector control (+/- 100% fuel change)
* Fuel change based on MAF, MAP, or Throttle Position
* Boost / Fuel cut defense (through MAF / MAP clamping)
* Boost Control (+/- 100% change)
* Plug-n-Play Harness with OEM style intercept connectors, no cutting or splicing is required
* Update firmware via USB, no need to return the CMD for updates
* Control Center Software ™ allows for unlimited map possibilities and real time tuning (base map included)
* Up to 48x48 tables dimensions allows for fine tuning and precise control
* Works in parallel with OBDII vehicles, even CAN-Bus systems
* CMD can draw power through the PC USB port, map changes can be made with the ignition off, or remove the CMD and bench program
* CAN-Bus communication and expansion options yields lightning fast communication speed with the Wideband2, LCD Display, and other Dynojet products. Not available on all models*.
