Question for AMS
Question for AMS
Hi guys, have a question about one of the products you guys are selling:
http://www.amsperformance.com/cart/W...mance.com.html
Is that a replacement for the stock eccentric bolt? Or does this bolt replace the regular bottom bolt and is used along side with the stock eccentric one?
After I installed my Bilstein HD with Swift springs I can only get -1.2 camber on one side and -1-8 on the other
I'm wondering if this bolt will get me closer to -2.
Also everywhere I read about whiteline camber bolts for Evo's, it said they should be 14mm for our cars. I'm pretty confused since your website stats it is 16mm, any help would be great.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Hey,
I was just in the shop to measure the strut bolts and they are in deed 14mm. The whiteline kit uses a special high tensile eccentric bolt to replace the factory upper strut clevis bolt. Here is a link to the instructions to these bolts.
Click Here
Also I spoke to Justin about your camber. Are you using the stock lower strut bolts in the new struts?? I ask because you can adjust the stock strut bolt to adjust camber to run either -1 or -2 by turning the bolt.
Click Here
falcontx
Jan 31, 2008 10:29 AM
