**Product Release**AMS Mitsubishi Lancer Evolution X MR/Ralliart Transmission Cooler
The AMS EVO X MR/Ralliart SST Transmission oil cooler kit is the first of its kind for the SST transmission. Many SST owners know all too well the problems plagued with the 6 speed dual clutch automatic transmission in the EVO X MR and Ralliart. Overheating is a common occurrence when driven hard. The AMS Trans. cooler helps to prevent that by using a high quality larger capacity heat exchanger with a fan that pulls air through the core the entire time the car is running. This helps to keep transmission temperatures in check and keep that pesky “slow down” light on the dash from coming on so often.
Features
* Full time fan to constantly pull in air through the cooler
* Directly replaces the OEM cooler, no cutting or modifying OEM plastics or body panels
* High quality oil cooler that adds an extra ˝ quart of fluid capacity
* Large frontal area of core allows for even better cooling
Kit Includes
* One of the best oil coolers on the market
* Electric fan that easily wires into the factory fuse box
* Stainless steel brackets for long life and a seamless install
* All necessary hardware and wiring to install in the OEM location and to OEM lines
Specifications
* Oil cooler capable of holding .5 additional quarts
* High quality 8” fan with stainless steel shroud
* 100% Stainless steel brackets
* Aeroquip push-lock fitting for OEM hose integration
Applications
* Mitsubishi Lancer Evolution 10 MR
* 2009+ Lancer Ralliart with SST Transmissions
**Click Here To Order**
We don't make a lower intercooler pipe for the Ralliart. However the stock EVO X lower intercooler pipe is an upgrade for them and our cooler fits with it.
So what are the test results of this vs. the stock cooler (i.e. tracked time/laps on stock vs. AMS upgrade)?
Your product description says it helps keep the "slow down" warning (SST overheating) from coming up so often. The "so often" part concerns me and makes me think the SST still overheats even with this upgraded cooler.
I know the AMS SST cooler upgrade is about half the price of others out there that claim the SST will never overheat with their kit, but I would still like to know how much better than stock this kit really is.
SSP Jeremy
EvoX 'For Sale' Engine Internals and Drivetrain
28
Aug 29, 2013 08:51 AM
AutoMotoSports
Jul 2, 2009 06:40 AM
