Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS 1000WHP GT-R build....lots of pics :)
Old Jun 4, 2010, 10:52 AM
  #271
MJ23FE's Avatar
Originally Posted by AutoMotoSports
to be honest we have yet to find a coating that will stand up...swain tech included
Mine held up very well for about 45k miles before it started to flake off. Even then, it was only the white top coating that started to flake. The gray base coat is still on there without issue.
Originally Posted by R/TErnie
what kind of filler rod do you use when welding cast iron to stainless?
nice work on the heat shields! Are you guys going to work on the airflow through the engine bay? Liquid cool the MVS gates?
+1
I would assume getting air to cool the engine bay as a whole would be essential. Does the OEM front bumper get enough air passing through it and the bay to keep temps down?
Originally Posted by BLKCarbonEVO
The heat shield looks sick! Have you guys ever tested turbo blankets? I know we use to use those on the hondas back in the day but I don't ever see anyone using them on the evo... The look of the blankets wouldn't be an issue since the heat shield would cover them!
Mikey
I know David Buschur did a little test with the new DEI Titanium turbo blanket which showed nice improvement on decreasing temps.
-Jalal
Old Jun 4, 2010, 10:58 AM
  #272
BLKCarbonEVO's Avatar
Would you happen to have the link to those results?
Mikey
Old Jun 8, 2010, 09:16 PM
  #273
homemade wrx's Avatar
With Formula SAE, I had done some extensive testing with various methods of blocking heat from the back of our driver seat/firewall was some ceramic cloth. We recieved it from Howmet as they use it in their titanium casting process.
Old Jun 9, 2010, 08:25 AM
  #274
R/TErnie's Avatar
we just coated the header, made a heat shield, and put goil foil on our carbon tub.
Air flow helps too!
Old Jun 9, 2010, 11:22 PM
  #275
noob5000000's Avatar
I don't own any cars that belong on this forum, but after coming across this thread a while ago I had to join to subscribe to this thread, and now I can no longer lurk in silence. The work being done here is amazing! I've always known AMS does good stuff, but this is just wild! Keep it up, I'm eagerly awaiting more updates .
Old Jun 11, 2010, 11:22 AM
  #276
uneedthis2's Avatar
Bumpity bump!
Old Jun 15, 2010, 01:04 PM
  #277
AutoMotoSports's Avatar
Thank you noob5000000!
On with some more updates:
NHRA regulations require a parachute on a car trapping more than 150mph in the quarter mile. Considering Frank and Mikes GT-R cut a 146.9mph on its maiden 9 sec pass we knew Chucks was going to need a parachute.
Justin stepped up the plate and built onto the existing cage with one hell of a parachute mount. The best part is the mount can be removed and the license plate installed in about 5 minutes and nobody is the wiser.
Imagine setting up a street race with a GT-R and all of a sudden he whips out a parachute to attach to the car....hahahaha
and on with the pictures:
This is going to be my new background!
We still have to paint the new bar supports but it came out GREAT!
Eric
Old Jun 15, 2010, 05:25 PM
  #278
MJ23FE's Avatar
homahgawd!!!
-Jalal
Old Jun 15, 2010, 05:27 PM
  #279
MJ23FE's Avatar
Mikey
Yessir!
https://www.evolutionm.net/forums/ev...ever-ends.html
-Jalal
Old Jun 15, 2010, 08:26 PM
  #280
Arkitek's Avatar
omg...this thing is going to be a beastly car. love the work you guys are doing! truely inspiring work!
Old Jun 16, 2010, 08:18 AM
  #281
uneedthis2's Avatar
Do you guys have a tube notching machine there in the shop?
Old Jun 16, 2010, 08:52 AM
  #282
Yes we do
Old Jun 16, 2010, 10:35 AM
  #283
R/TErnie's Avatar
nice work. Never seen a lefty tig weld before
Old Jun 16, 2010, 11:02 AM
  #284
lude2evo's Avatar
^^^ damn good eye
Old Jun 18, 2010, 12:56 PM
  #285
The AMS GT-R SR series Turbo kit is really starting to take shape now. With custom silicone now here and attached the kit is almost ready for testing.
In the pictures below you will see much of what won't be visable in the car. This setup is what will go on Tim sanders GT-R. Chucks will be a little larger.
Also the Compressor outlet pipe for Chuck and Tim's car will be hand welded as is seen in the pics but the production kits will have a casted aluminum piece in its place with a smoother transition and more OEM like fit and finish.
With all of this done the next step is to finish the oil and water lines and drop the engine back in the car. From there we can finish the downpipes and finally get Tim's car on the dyno!
I can't wait to hear what these turbo's are going to sound like with that intake pipe on there
I love this viewpoint! You can really see the size of these turbo's from this angle.
Keep in mind in the below picture that intake pipe is unfinished. We merely had a pipe in there for clearance reasons. The final version will of course be all the way to the front of the car.
Quick Reply: AMS 1000WHP GT-R build....lots of pics :)
