**AMS Product Release**Mitsubishi Ralliart Twin Tip Cat-Back Exhaust**
AMS Mitsubishi Ralliart Twin Tip Cat-Back Exhaust
The AMS Mitsubishi Ralliart Twin Tip Cat-Back Exhaust is the perfect system for those seeking an attractive exhaust note and significant increase in power with the choice of OEM style tips or 4” slash cut tips for an aggressive look. Utilizing top quality slip-fit clamps, you’re guaranteed perfect fitment and maximum adjustability. The AMS system has undergone countless hours of research and development and has been designed to make the most horse power as well as shed some weight off your Ralliart. Our exhaust features mandrel bent piping for the best exhaust flow and does not have any restrictions like other popular exhaust systems that "neck down" and hurt performance.
Like all other AMS exhaust products this Twin Tip Cat-Back Exhaust is TIG welded with 100% 304 stainless components including the flanges and hangers. The system utilizes factory exhaust hangers and includes a high quality polished muffler and matching polished exhaust tips and includes all gaskets and hardware for installation. By simply installing this exhaust system you can expect to see as much as 10+ Wheel Horsepower gains over stock without even re-tuning the ECU!
Features
- 3" diameter primary pipe
- Twin 2.5” exhaust pipes exiting muffler
- 100% Stainless Steel construction. No mild steel flanges or hangers
- Option of OEM style or 4” slash cut tips
- 10+ Wheel Horsepower gains over stock
- 10 lbs. weight savings
- 6" Of Ground clearance, no lower than the factory cross member
- Bolts up to the factory catalytic converter, AMS High-Flow Cat or AMS Test-Pipe
- Includes gaskets and hardware
- Unrivaled fit and finish
- Cat-Back Exhaust with Muffler
- Top quality slip-fit clamps
- Gaskets and Hardware
- 304 Stainless Steel
- 3” Piping .049” Wall Thickness
- Polished Muffler and Matching Polished Tips
- 3/8" Thick Stainless Steel Flanges
- 2009+ Mitsubishi Lancer Ralliart
Click Here for More Information
By looking at the pic, it looks like the short pipe with the tips fit on the muffler with a slip clamp. You were probably thinking the same as me order it now and see if u can just buy the 4" tips later and switch them out.
Yes the tips will be interchangeable! I have fitted both types on my car for testing. If we do ever manage to source Ti style tips, they would be most likely be able to be purchased separately.
On your site it has the option for round tips or slash cut tips. Which option would be the ACTUAL round tips that dont look like the OEM style ones? Im alittle confused cuz in the description it says "choice of OEM style tips or 4” slash cut tips for an aggressive look"
So im not 100% sure which is which, I want this style tips.
Alright cool thanks. Do you know if your going to add the dual exhaust as an option in your stage 1 package anytime soon? I so I think i would buy that instead of just the exhaust.
TitanMotorsport
16
Sep 16, 2015 01:21 PM
TitanMotorsport
13
Jun 23, 2014 02:23 PM
teamturbo
EvoX 'For Sale' External Engine / Power
Jul 28, 2009 03:49 PM
