AMS Race Shaft kit install
I recently bought the Race Balance Shaft delete kit and was wondering about the install. In the kit, there's 3 bearings. One has no holes and the others have one hole on each. My main question is in what order do you install these?
My machine shop pressed in the blank (no hole) bearing where the race shaft is to be mounted and the other 2 with holes are mounted to the other shaft where I'm deleting that shaft (both holes are rotated 180 to block off passage). I'm wondering if this is the right order or if they got it wrong.
Doesn't sound right at all. The oil pump shaft that has been machined down still needs oil.
disregard, oil comes through the hollow shaft on this side.
Akito
Lancer How Tos / Installations
19
Dec 28, 2020 05:53 PM
ReivaXVrai2
75
Jan 21, 2017 07:28 PM
mr 2.3 evo
12
May 28, 2009 12:19 PM
