Turbo kit?
#33
Originally posted by xkpbreaker
how does ur financing work?? ... i want to do it for this turbo kit!!!!
-shahul
#37
hey, you recommended cams with the kit....I was wondering if someone had either the 264/272 or the 272/272 HKS setup (most popular combos)...
would you need the valve springs and retainers with you Gt35R kit? would the 272/272 be better with the larger turbo?
sorry for all the questions........
-Shahul
-Shahul
#38
Well, can we go without cams? I dunno if i want to do any internal mods for right now. Installation cost is goign to be an arm or a leg, so if the kits can make good power with cams support, I think that would be great....
#39
Originally posted by boiwunder
Well in addition to the kit hear is a list of recommended and required mods.
Required:
-3" Cat Back Exhaust with 3" Cat or 3" Testpipe
-Walbro Fuel Pump
-680cc Injectors
-Fuel Control ie; S-AFC2, AEM EMS, UTEC, Emanage, Xede.....
-Basic BOV Upgrade ie; Forge, Type-S...
Recommended:
-FMIC Upgrade
-Cams
-Heads Studs if you plan to boost over 20 PSI
-Clutch Upgrade (type depends on HP level)
-kris
Required:
-Walbro Fuel Pump
-680cc Injectors
Recommended:
-FMIC Upgrade
-Cams
-kris
-Shahul
#40
-Shahul
-Shahul
#44
Eric
I totally want to get that setup!! How much exactly for it? I finally found some cams and want to do this at the same time. Should I get some forged internals or would that be overkill?
