Stage 3 kit
fidanza has 5 mount points, HKS has 3. Some say the more mounting points the safer. However if you don't tighten the fasteners enough either one will come loose. I'd use thread lock on them after you have them dialed in. Both will yield the same power results, only difference I would say would be in the weight. I'd go with the fidanza the price is right, use the extra $ for a fuel pump
You are buying the HKS name with there cam gears. I have the findanza gears and IMO they are a better build than the HKS ones,ive seen them they look pretty. 5pt lockdown or 3 pt, I take the 5 any day
Originally posted by AutoMotoSports
Sorry for the late response. Honestly the only real difference is one is purple and has a pretty HKS logo on it
Eric
Eric
-shahul
