AWD Motorsports Haltech Dash!!!
We spent much of Saturdy and today setting up Haltech / Racepak Dash in the Evo.. Ive had the Dash for quite sometime and Finally now that i have a Racecar I found it fitting to install the dash.. Nice to have everything all in 1 unit on the same Screen.. This dash can monitor anything the ECU can monitor.. Some things it can do..
Monitor Boost, A/F, EGT, Coolant Temp, Air Temp, Oil Pressue, Fuel Pressure, Oil Temp, Gear Position, Shift Light, Warning Lights..
Another Cool thing it can do is is measure Oil Pressure based on RPM and give warning lights.. Fuel Pressure vs. RPM with Boost Reference as well.. So if the FUel Pressure isnt at the right level based on boost reference itll give warning lights..
Here is a pic of it just installed but not setup 100% yet...
And for those that dont know what the title refers too.. Its our tag on the car..
Presently the dash displays RPM's, AFR's, Boost pressure, Coolant temps, Oil pressure, Battery voltage and Gear selection. Warning lights are set for low/high coolant temps, low oil pressure vs rpm and low battery voltage.
Shift lights are also activated. Basically whatever the ecu monitors the dash can display.
