Buschur Racing , Gsc Cams, Kelford Cams , Ferrea , ACT , Exedy, ARP.. All In Stock!!
IF YOU FIND IT CHEAPER ANYWHERE WE WILL BEAT IT..
AWD Motorsports Spec 272 Cams 550.00 Shipped
GSC s1 & s2 Cams.. IN STOCK w/ New Design.. PM FOR PRICING
Fuel Injector Clinic 2150cc PnP Evo Injectors.. PM for Pricing..
AWD SPEC Wiseco Pistons 85mm / 85.5mm 10:1 1400HD 649.00 SHIPPED
The GSC Beehive springs are available in 3 different retainer and spring seat options
Part number 5041 includes new 4340 Chro-molly spring seats (these won't crack like others aluminum seats) and GSC’s Titanium Retainer set. This kit is capable of 11000RPMS, with as much as 12.5mm of lift (or .285" of camlift). This is a must have for anyone pushing the limits. If you have had problems with valve float or throwing rocker arms this is the spring set that will cure your problems for good... 415.00 SHIPPED
Spring pressure:
Seat at 1.46"= 95 pounds
.300"= 200 pounds
.400"= 250 pounds
CoilBind .560"
Part number 5040 includes new Titanium Retainer set and will utilities the stock oem seat, this is a simple change with no need to change seals or spring seats. This kit is capable of 9500RPMS, with as much as 12.5mm of lift (or .285" of camlift). This is a must have for anyone pushing the limits but on less aggressive camshafts such as the S1 on road racing setups or S2 all setups. 395.00 SHIPPED
Spring pressure:
Seat at 1.54"= 75 pounds
.300"= 170 pounds
.400"= 220 pounds
CoilBind .620"
Max lift 12.5mm of lift (or .285" of camlift)
Part number 5039 includes a set of GSC Beehive Springs for use on the stock seat and OEM retainer. This kit is capable of 8500RPMS (or south of 9k), with as much as 11.4mm of lift (or .259" of camlift). These are designed as a drop in spring to use with the S2 camshaft set. 220.00 SHIPPED
Spring pressure:
Seat at 1.56"= 68pounds
.300"= 160 pounds
.400"= 210 pounds
CoilBind .625"
Max lift 11.4mmof lift (or .259" of camlift)
Buschur Custom DROP-IN 2.0L Coated JE Pistons.. W/ Rings, Wristpins, Locks.. 705.00 Shipped
Crower Billet Rods.. Perfect Combo for Dropin Pistons!! 750.00 Shipped
BUSCHUR RACING BF272 Evo VIII Cams 615.00 Shipped
Buschur Racing 2.0L Shortblock.. IN STOCK.. Your choice of JE Pistons w/ Crower Rods, Manley Turbo Tuff or GRP Aluminum Rods!!
( Crower Rods / Manley Rods 3100.00 / GRP Aluminum Rods 3400.00 )
Kelford Evo VIII and IX Cams.. PM FOR PRICING..
ARP L19 Headstuds 245.00 Shipped
Fidanza Cam Gears Silver 210.00 Shipped
Brian Crower #0100 Springs and Retainers 225.00 Shipped
Eagle Rods 319.00 Shipped
Supertech Dual Springs and Retainers w/ Locators & Valve Seals 360.00 SHIPPED
Exedy Twin Disc Rebuild Discs.. 470.00 Shipped
ACT HDSS Clutch Kits IN STOCK.. PM FOR LOWEST PRICING!!
Spring pressure:
.300"= 200 pounds
.400"= 250 pounds
CoilBind .560"
Spring pressure:
.300"= 170 pounds
.400"= 220 pounds
CoilBind .620"
Spring pressure:
.300"= 160 pounds
.400"= 210 pounds
CoilBind .625"
Shaun@AWDMotorsports
174
Jan 28, 2014 09:27 AM
AWD Motorsports
AWD Motorsports - Florida
Jan 5, 2012 02:59 PM
AWD Motorsports
Dec 3, 2010 02:02 PM
AWD Motorsports
Southeast Region
75
Aug 23, 2008 08:00 AM
AWD Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
17
Apr 29, 2008 08:46 AM
