AWD Motorsports - Florida AWD Motorsports is a South Florida based Mitsubishi Evo Specialist.. Home of Multiple 8, 9 & 10 second Evos!!!
Fortune Auto Coilovers IN STOCK!!! BEST PRICING AROUND!!!!
Old May 2, 2011, 12:29 PM
AWD Motorsports's Avatar
We are proud to bring you coilovers from Fortune Auto.. One of the biggest names in High Performance Coilovers.. Custom Spring Rates available along with the SWIFT Spring Upgrades.. Any questions feel free to email or Pm us.. Thanks!!
500 Series Coilovers 1149.00 SHIPPED ( add 295.00 for Swift Spring Upgrade )
Fortune Auto 500 Series Coilover Specs
DIGRESSIVE* All Fortune Auto shocks use a superior DIGRESSIVE piston. This technology allows for stiff, progressive (linear) damping at low stroke speeds. This helps to control vehicle body motion like roll, dive and squat. However at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
Dyno tested***
Mono-tube shock design
IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
Stainless steel body / piston
30-way adjustable dampers
Pillowball mounts
Forged aluminum locking collars
Dust boots on all pistons
Digressive* 50mm piston-57mm piston housing (beyond the industry standard of 44-47mm)
Anodized aluminum camber plates** on front upper-mounts
Fully anodized body
1 year Manufacturer's Warranty
Height adjustment independent of preload
ISO 9002 certification
***Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers
Old May 3, 2011, 09:36 AM
In stock and ready to ship!!!
Old May 3, 2011, 05:40 PM
_Chris_'s Avatar
Interested.
Old May 4, 2011, 09:30 AM
Old May 4, 2011, 01:53 PM
_Chris_'s Avatar
Are these the new inverted(V3) style?
Old May 5, 2011, 10:14 AM
BOOSTINJAE's Avatar
I think i might grab a set with the swift spec.. i was saving up to get ohlins but these look pretty good.
Old May 5, 2011, 10:33 AM
No they are not but they will be released soon
Old May 6, 2011, 09:36 AM
ttt
Old May 9, 2011, 10:10 AM
Old May 10, 2011, 09:18 AM
bump
Old May 11, 2011, 09:41 AM
ttt
Old May 12, 2011, 10:04 AM
ttt
Old May 16, 2011, 09:42 AM
Old May 17, 2011, 09:13 AM
ttt
Old May 18, 2011, 11:49 AM
ttt
Quick Reply: Fortune Auto Coilovers IN STOCK!!! BEST PRICING AROUND!!!!
