Cobb AP PSI
Old Jan 18, 2012 | 04:46 PM
OkcSupra's Avatar
Originally Posted by metagalaxxy22
i have the cobb stage 2 ap for my ix..i have tbe and injen cai, i am on stage 2 flash v 101 91 oct ca...
i belive that since i got the car the throttle shaft seals are leaking.
it has always gone to 20-21psi...but now im lucky to hit 20psi..sometimes i only peak at 13 psi..
what do you guys think i will be hitting if i fix the leak..??
i have a mbc... but i think since its flashed at 91 oct i think maybe 22psi would be the norm??
suggesstions?
sorry for the dumb question
why do you have a mbc? your not suppose to, your boost is controlled by the ebc that comes stock on your car.
Old Jan 18, 2012 | 05:27 PM
metagalaxxy22's Avatar
hmmm im not sure lol..good question..ill have to look into that.
how would i go about reconnecting it with out the mbc?
sorry im new in the world of turbo cars..ive alwas had hondas before..
Old Jan 19, 2012 | 11:29 AM
i just talked to cobb today. it is fine to have a manual boost controller if i want to up the boost a bit...which i will up it from 20.5 psi to 22 psi...should be safe as l;ong as my aem wego reads around 11 a/f ratio at wot
Old Jan 23, 2012 | 03:39 PM
OkcSupra's Avatar
well if you take it off you will hit 23psi.. which you are suppose to on the stage 2 map, +-.8psi
Old Jan 24, 2012 | 05:49 AM
couldnt i just adjust my mbc to 23 psi? seems a bit high for me. actually at stage 2 91 oct 22 psi is pretty much max its really suppossed to only boost to 21.5 psi on that setting. (it says so on cobbs website)
Old Jan 24, 2012 | 07:20 AM
rodeopunk_je87's Avatar
Originally Posted by Jookies
So I installe dmy Cobb AP today ( yayyy) with the stage 1 map (cobb sf intake) and the map states that boost shoul dbe ~24 +/- .8. I did 2 WOT pulls to test it, and the pulls had 26.6 and 27 PSI as the peak it hit, is this a dangerous amount of overboosting?
How cold is it in Jersey? When I spoke to Cobb about overboosting, they said I should switch to LWG in colder temps. I had a problem with overboosting. So from now on, I'm going to run LWG in the winter and NWG during the rest of the year.
Brokeassevo
Sep 1, 2016 05:58 AM
t3am 83rd
Cobb AccessPORT
Apr 28, 2016 08:16 AM
SOG RA
34
Sep 17, 2015 09:14 PM
Kahrs
Apr 4, 2011 10:44 AM
madfast
Mar 3, 2010 02:49 PM
Quick Reply: Cobb AP PSI
