AccessTunerRace question - changing stationary rev limit in a MR
I tried changing the stationary rev limit in the Stage 2 SF 93 octane map for my '11 MR and I had no luck. From default, the limit is 5500 rpm, but after having launch issues, I tried changing it to something lower like 3000 rpm. I saved the map and ran it on my ECU but the engine still revs to 5500 when standing still in S-Sport mode. Am I doing something wrong? Where do you change the values for RPM for launch control? Or is that something I can't change altogether?
AFAIK, the LC settings in the MR should function identically to how the GSR works. Have you tried doing a park or neutral free rev to see if the stationary limiter is engaging? I believe there are some special steps needed to put the car into "Launch" mode, but do not recall the specifics. What steps are you taking to attempt a launch?
Thank You,
-Braden @ COBB
franzcars
Jul 26, 2023 09:27 AM
Cutty
Apr 6, 2016 12:18 PM
